how a bad compression gauge cost racebum thousands
This is one of those educational posts.
As some of you know a month or so ago i blew up yet another type r engine. compression read 160-160-90-160
sounds like a tired R motor with a cracked piston doesn't it?
have another jdm R motor show up the other day and compression test it on the floor cold. hovered between 140 and 150psi. floored i just couldn't figure it out..this jdm motor had tan exhaust valves and zero carbon on the seats. i double check cam timing since that can effect compression. nope, it's dead on.
i get another compression gauge, engine has 230+psi cold. not only that but it took all of 2 cranks to get it
had i known this i would have tossed another piston in the first motor and ran it. i figured it was a tired motor and needed to be rebuilt. an itr with 160lbs is really low right?
moral of the story is don't bet the farm on a harbor freight compression gauge.
my 160lb itr engine was probably 220ish minus the one cylinder i could have tossed an oe piston in and fixed
damn. shoulda done a leakdown, bud.
or invested in a higher caliber tool. compression tester is pretty critical.
but oh well. no use cryin over spilled milk. take it as a lesson learned i guess
racebum did you buy a new gauge? curious which brand you went with im about ready to toss my dads early 1980s compression tester as I also think it doesnt give accurate results at all
i also believe those tube screw in adapters effect the numbers. you're going to be most accurate just screwing the hose in the cylinder. the tube we tried on this gauge dropped the readings as well
least that's where i would place it.
a new snap on gauge is 89
http://buy1.snapon.com/catalog/item....re&dir=catalog
and another 40 for the hose
http://buy1.snapon.com/catalog/tools...e=snapon-store
that's 120 plus shipping. the KD tools tester
is 35 shipped
http://www.amazon.com/KD-Tools-KDT24...sr=1-1-catcorr
and is available special order at sears.
one of those things. i have a snap on flex ratchet that's 3x the cost of a gearwrench. personal call on if you want to spend the same on a compression gauge. i will say that i've never had any bad experience with KD or gearwrench for mid level tools
also hate the metal tube extensions. tested another one today and it f'ked the numbers. i highly suggest just going hose to spark plug hole.
could be the reason snap on does not sell metal tube extensions.
from what i can tell the tubes hold too much air and reduce air pressure at the gauge. think of a pump in a small chamber. it will create more pressure than the same pump in a larger chamber.
tried a metal tube with actron gauge on the pictured R engine you see on my shop floor. every cylinder read 140psi, without the tube it's the 240-245psi you see pictured
Sucks man - sorry to hear you had to learn the hard way
Correct me if I'm wrong though, I always thought that compression test readings were more of a "relative" measure. As in, compare the readings of the same tool between different cylinders rather than looking at the "actual PSI" reading. So if 3 cylinders show 160 and 1 shows 90, then compression test says "problem in that 1 cylinder." (as opposed to saying "need to improve compression by x amount of PSI"). Curious to hear your thoughts, thanks
BUT
compression numbers are also how you can gauge the life of an engine. when you start getting leakage in the valves and in the bottom end numbers gradually go down over time.
in the case of my last R engine, that one cylinder did have a cracked ringland or mangled rings. but, i assumed the other 3 were down from mileage and track use. 160 is basically the end of the life for an R engine. oil burning also gives some clue but with a cracked ringland i was eating a quart every 200-300 miles. i considered a rebuild but thought, ****, how much hell has the head seen? anyway, had i gotten 220lbs which is what an accurate gauge would have shown based on the differences i tested, 220 isn't down that much from stock on an R and still has some life to go. 250 is basically like new on these engines which you'll either see warm or cold with a few drops of oil
had a realized it really was just one cylinder i would have bought a 75 dollar oe jdm itr piston, ran the ball hone, bolted it in and drove. rather than part it and buy another jdm R engine
side note: i really need to buy a leakdown tester
found a couple
http://www.ebay.com/itm/Total-Seal-1...ht_1884wt_1163
which looks to be a good one, total seal is a ring manf
or, the generic brand
http://www.ebay.com/itm/JEGS-Perform...#ht_1730wt_905
KD is part of the dahner tool group, it's what, gearwrench level, above craftsman but below matco?
is 35 shipped
is 35 shipped
not sure on the kd
personally i'm always keeping two on hand from different brands after this. if something seems suspect try the other one. it's unlikely two will fail to the same degree
and im sure different models do different things
i just wanted to put all this out there so people can burn this information to memory and if they are caught in a situation, recall what they read and try a different gauge or loose the tube when they do a compression check
Racebum, did you take the head off and inspect the first motor? Would have seen the other pistons were fine, could have just re-ring'd it, changed the cracked piston, and been on your merry way. Sucks that the gauge caused so much headache though
You are correct. Different gauges may read differently, that's why the general rule of thumb is you don't want more than 10% variance between cylinders.
that's exactly what i would have done. there was only a 5lb difference between the healthy cylinders
172,000kms
i got the cluster out of the car it was pulled from, came with 68,000
engine still had a lot of life left with work i had the skillset to complete, total screw up on my part
just wanted to share so no one else makes the same mistake
Cool Cool Island Breezes. BOY-EE
What'd u do with the old motor? Why not rebuild it and have a spare...or sell it?
