91 Accord radio stays on after key is turned off
Old Mar 31, 2012 | 06:29 PM
invader_zim's Avatar
Default 91 Accord radio stays on after key is turned off
Earlier today I was at Home Depot and when I turned the car off to get out the radio kept playing even though the key was off and taken out of the ignition. both the radio and cigarette light had power. The problem has since gona away, I just wanna know if anyone else has had or knows what the problem is. Any suggestions on what it could be?
Old Apr 1, 2012 | 06:06 AM
Lost Again's Avatar
Default Re: 91 Accord radio stays on after key is turned off
Stock set up or is there an aftermarket system installed?
Did you happen to have your cell phone plugged into the lighter?
Old Apr 1, 2012 | 09:08 AM
Aftermarket radio installed using a harness, cell phone was not plugged in. I have had my cell plugged in before and everything worked as it should.
Old Apr 4, 2012 | 09:52 PM
TejasNW's Avatar
Ignition switches in the column go wear out. when they do the key can come out without turning the switch all the way to the off position. If it real bad you can start the car, and pull out the keys and toss 'em in the seat next to you. Yes, experience it on my '91 a few years ago.
Old Apr 4, 2012 | 11:22 PM
Cant pull the key out with the key turned yet. It hasn't done it since that day so I dunno. I guess if it happens again I will get another ignition switch
Marva gerhard
Jul 31, 2017 09:01 PM
ldutton
Sep 7, 2011 04:15 PM
jdmyelloweg
Feb 22, 2011 05:10 PM
Citystars
Dec 19, 2007 01:38 PM
Alohachic
Nov 13, 2004 04:05 PM
