Need help
I did a mini me swap with a turbo in a 88hatch. Everything is in. Did the mpfi chipped p28 and got unite for ecu. When u turn the key nothing. I have 12v on one side of the starter and when u turn the key to start there is no power on the other side of the starter. Have changed the starter to. What could be? Wiring? Any ideas would help
has to be wiring, did you use a voltage meter by the ignation to see if any power is going to it, ck the wire harness connection going to the fuse box.
and i know this is stupid, but u never know, did you hook up the single wire to the starter??
if you tapped into the either the signal wire or the main power wire your probably not getting enough amperage to the starter. try running your vtec through a different circuit and see if it works. could also be the relay.
slow_sihatch
16
Aug 4, 2015 04:35 PM
Nathan_volcom
Aug 26, 2012 10:17 AM
ahem ahem
Aug 23, 2009 06:28 PM
