Balljoint installation. Air Tool needed??
Old Mar 31, 2012 | 01:30 AM
DawgC2's Avatar
Default Balljoint installation. Air Tool needed??
Im about to replace my worn lower ball joint with spoon bumpsteer. I wonder if I need an impact gun to drive the balljoint press tool or "manpower with a rachet" would be powerful enough to press the balljoint in???
Old Mar 31, 2012 | 08:35 AM
albertoG87's Avatar
Default Re: Balljoint installation. Air Tool needed??
I hammered the old ball joint out with a hammer and then pressed the new one in with a hammer also. Only i wouldn't advise using the hammer to press in your SPOON ones in because when I did mine with a hammer it chewed up the top metal portion of the ball joint...just food for thought.
Old Mar 31, 2012 | 08:59 AM
cagedGSR's Avatar
It would definitely be easier with air tools. they do make electric impacts it you don't have access to air, they work good too. Definitely don't try putting it in with a hammer. Like the guy above me said you will chew it up.
Good luck!
Old Mar 31, 2012 | 09:26 AM
DawgC2's Avatar
Good luck!
Thx Thx
Old Mar 31, 2012 | 09:39 AM
el crapitan's Avatar
you can use a hammer, just don't hammer directly on the joint lol. use a socket the appropriate size. or you can suck the joint in with the nut.
just make sure to use some emery cloth in the bore so it's good and clean. that way goe in smoothly and seats proper
Old Mar 31, 2012 | 10:52 AM
bgdriver's Avatar
just go and rent the c-clamp tool from a parts store, makes both ball joints an hour job.
Old Mar 31, 2012 | 03:13 PM
^^yea a balljoint press works great
Old Mar 31, 2012 | 05:46 PM
94rs-turbo's Avatar
sledge out, brass hammer in is my style lol
Old Mar 31, 2012 | 06:06 PM
Lord Helmet's Avatar
LOL that's the way I do it To OP remember to remove the retaining C-clip before you hammer the balljoint out.
thelizard_king
Suspension & Brakes
Aug 10, 2017 08:28 PM
pliskin679
May 8, 2009 01:02 PM
sirtef9
13
Dec 27, 2007 01:37 PM
COLLIER67
23
Jun 19, 2007 08:45 PM
Steve91
10
Nov 27, 2002 12:02 AM
