1992 honda accord heater blower problems
Old Mar 30, 2012 | 11:47 PM
Muydos's Avatar
Default 1992 honda accord heater blower problems
I'm new to the fourms I did a little research on the fourms to see if any one had simler problems and nothing yet... So heres what wrong;
When I turn on the heater blower nothing happens what so ever! So I took apart the heater assamably to check the motor and reley swich... Didn't have the the equiment to really test but I took a live wire to it, blower turned on fine! So I figured the swich replaced it, and still nothing... Checked the fuses there both good (going to change the one under the hood just for the hell of it as soon as I find one) but if it's not that is there something else I should check on?
Old Apr 1, 2012 | 05:28 AM
Lost Again's Avatar
Default Re: 1992 honda accord heater blower problems
The relay?
Do you have a voltmeter?
Old Apr 1, 2012 | 11:31 AM
Muydos's Avatar
Well here's an update: I went got the fuse checked out for the hell of it, it's good, I don't have a voltmeter but I do have a 6-12v light check thing it works the same way I think just doesn't tell me the volts but there's power going to the relay as far as I can tell. I went and talked to someone over at a near by part store (knechts) and said it could be faulty wiring...
Old Apr 1, 2012 | 12:24 PM
Nicefeet's Avatar
The chances are your blower motor is junk. It more than likely has a bad spot on the armature. Mine did the same thing sometimes it would work and other times I got nothing. BTW removing these things is kind of a bite in the *** so replace the resister pack while you have it apart.
Old Apr 1, 2012 | 08:00 PM
Romeguy2's Avatar
I am new to the forum. I have the same problem...I think. 1990 Accord EX. The blower for both the heater and the AC just stopped. Could it be just a bad blower switch?
Can any one direct me to find out how to test the actual motor or other electrical part. I am really lame when it comes to electricity :/
Thanks!
Old Apr 5, 2012 | 04:42 PM
Muydos's Avatar
Yea that's what's I'm leaning towards myself... So I might just out and get a used one, the weathers finily starting to turn around so I don't need it as much, but it'd be nice to have come summer.
Old Jun 3, 2012 | 02:01 PM
Muydos's Avatar
Originally Posted by Lost Again
The relay?
Problem sloved ot was in fact the relay!
Lefty1982
Jun 7, 2019 08:22 AM
johhnyu2
Apr 1, 2008 11:38 AM
jdminthemakin
Jun 17, 2006 10:35 PM
hamburgler
Sep 16, 2005 03:40 AM
jester
12
Sep 19, 2003 09:38 AM
