Car studders uphill?
Old Mar 30, 2012 | 08:41 PM
B4RK3R's Avatar
Default Car studders uphill?
Ok so I have a 1991 Integra and my car started "studdering" uphill today. It happens when im in a higher gear (5th) and I press the gas to maintain speed up a hill (not necessarily a steep one either) , my car fels like its slipping or studdering under load. It also happens when I slow down and keep it in a higher gear to take a corner or I searched and found a few things it could be
-Clogged fuel filter (replaced it about two weeks ago, but didnt torque to specs due to lack of torque wrench, but its tight no leaks)
-Bad clutch (shop replaced clutch and flywheel two weeks ago so its good)
-bad MAP sensor (f**king thing is stupid expensive to replace, ill buy a new car before I replace it)
- Timing out of whack (might be able to borrow timing gun)
- Clogged cat (When I got my exhaust back in june, my mechanic said it looked like the inside of the cat was melting away and I should replace soon)
So my question is has anyone had the same problem and how did you fix it?
Old Mar 30, 2012 | 08:53 PM
el crapitan's Avatar
Default Re: Car studders uphill?
don't ask that question please. it's a common symptom, with multiple possible causes.
try disconnecting the cat and see if it goes away.
if not, check timing with a light
Old Mar 31, 2012 | 07:13 AM
B4RK3R's Avatar
I'll try taking off the cat this week and see
Old Apr 1, 2012 | 02:23 PM
tegman97's Avatar
Is it misfiring? Not long after I got my integra it started missing going up hills/under load but ran fine otherwise. I changed the plugs and that took care of it. But considering what you said about the cat I'd just try disconnecting it first
cpl rampage
Acura TL, RL & ZDX
Jan 11, 2012 06:27 PM
SuM Honda
Jul 27, 2008 07:08 PM
IMMORTAL-B18
Jun 26, 2004 02:36 AM
Johnny Blaze
Aug 18, 2002 02:02 PM
mntdewred
Jul 14, 2002 11:38 AM
