TWM built b20vtec NEW
Old Mar 30, 2012 | 07:56 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default TWM built b20vtec NEW
Seeing what I can get for my previous unfinished build
Now Parting out
Head- 1000 OBO
Block- 1500- sold for 1000 to local.
Trans- 1200 OBO
ITBs- 1000 OBO
Also selling a set of pretty mint ADVAN SA3R's no tires- 700 obo
16x7 +32 the black and red ones
Have all 4 coins
Have all 4 locking rings
Have all 4 center caps
and all 4 locking nuts
and even have the original wrench.
Located in Beaufort, SC more people know Parris island.
The motor is assembled awaiting to be installed, but, at this point in life i just don't think I'm going to be able to bring myself to finishing it. I have somewhat lost interest in the build/car and have a family and another car currently trying to finish building.
Might start another thread to start parting the car and wheels.
Going to try and sell as a whole, which is probably unlikely. Then part it.
Jdm B20b block 84.5mm - SOLD
internals consist of
LS crank
Eagle H-beam Rods w/ arp 2200 bolts
Supertech 84.5mm 12.5:1 Compression pistons
Supertech rings 84.5mm ( have been filed to supertech specs)
CTR n1 crank pulley
(entire rotating assembly has been balance/ blueprinted)
Moroso Oil Pan
Brand new ITR oil pump
Brand new ITR water pump
All brand new honda gaskets, seals, Orings
ARP head studs
Golden Eagle 84.5mm head gasket
Golden Eagle LSVTEC kit
p72 GSR head (has 5k miles)
Rocket Motorsports Gen1 Springs
Rocket Motorsports Gen1 Titanium Retainers
ITR valves
Port & Polish
Honda guides
Honda valve seals
2001 ITR cams
MFactory Adjustable cam gears
Hondata intake Mani gasket
2 intake manifold options
1. blox (itr rep) intake mani
or the all mighty
2. TWM 52mm individual throttle bodies
comes with the matching:
TWM fuel rail
TWM Fuel Pressure regulator
Has 06 s2000 360cc injectors
(one of the velocity stacks have been shaved to clear master cylinder, as they were previously in a crx)
ITR trans (told has 40k)
Shifts like melted butter
4.4fd
Stock LSD
Clutchmasters 7.5lb flywheel
Have a clutch to go with it, just forgot what it is. lol.
Im sure that Im forgetting some stuff. but that should be the guts of it.
Old Mar 30, 2012 | 08:05 PM
turbob16ef's Avatar
Default Re: TWM built b20vtec NEW
As for price, Im not to sure were to start. so let start at 4500 obo
I also have extra set of used sysc LS rods attached to arias pistons. Not to sure of comp. I think there 10.5ish.
A set of BNIB 84mm 12.5:1 comp supertech pistons
A built for boost bottom end with 500miles. but has a whole in block. ha. pistons are good, as all the misc stuff.
KAZZ lsd without speedo gear
Toms Racing Red suede CF backing fixed racing seat with crx rail. i think its a 34waist.
A Pro top line GSR head. Disassembled/ maybe missing somethings.- has roughly 750miles on it. cam snapped and scuffed 2 or 3 of the cam journals.
Old Apr 3, 2012 | 05:08 AM
turbob16ef's Avatar
BUMP.
Am very negotiable.
And will seperate
Old Apr 3, 2012 | 09:03 AM
GSR615's Avatar
How much for longbloxk
Old Apr 4, 2012 | 08:43 PM
turbob16ef's Avatar
Complete long block including itb's 3700 obo.
With the blox mani 3200 obo.
Old Apr 4, 2012 | 08:48 PM
turbob16ef's Avatar
Forgot to to put has a gates racing timing belt on the motor.
Also has alternator with unorthodox light weight pulley.
Can also throw in a rep big tube header. Kinda beat though.
And whatever else in have in my garage.
Old Apr 12, 2012 | 06:20 PM
turbob16ef's Avatar
BUMP..... need this stuff sorta gone
throw me some offers
Old Apr 30, 2012 | 04:07 PM
turbob16ef's Avatar
Bump- need it sold
Short block is gone
es01civy
Sep 8, 2015 11:45 AM
rahzelhx
Northwest (Sales)
31
Feb 3, 2013 01:16 PM
rahzelhx
Jan 16, 2013 05:08 AM
b1_teg_god
Northwest (Sales)
18
Jun 7, 2009 05:00 AM
