obd2 sohc zc goin in obd0 rex
ok so i just got recieved my zc today. I'm going through and taking p/s pump and a/c comp. ect. ect. off . then i expose the injector clips, remove one and pull my newly made harness for an obd0 zc over (made by monotech) and of course the plugs dont slip onto the injectors, i knew that much would happen, so to make this work can i just cut the plugs off and wire them into my new harness?? and will i need the injector resistor box still with those obd2 injectors. (if this will even work)?
Dohc 4door Rye
Mar 2, 2006 11:17 AM
miketurbohonda
Nov 27, 2004 06:12 AM
b17a1teg
Jun 10, 2004 11:17 AM
