D16a6 head on d15b6 block??
Old Mar 30, 2012 | 09:09 AM
Skreamizm's Avatar
Default D16a6 head on d15b6 block??
I have an 89 Crx HF, and I was wondering if I could put a d16a6 head on my d15a6 block? I've found an a6 head for dirt cheap. Is it possible? If so what do I need to do?
Old Mar 31, 2012 | 08:12 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: D16a6 head on d15b6 block??
You can swap the head onto your B6 but you'll need to make sure you have the 16 valve pistons (PM3) installed first.
Old Jul 5, 2012 | 08:25 PM
probowler2286's Avatar
I realize thread is old, but would I be correct in assuming same is true for z6 head, or any 16v head for that matter?
Old Jul 5, 2012 | 09:34 PM
sxysweed's Avatar
Yes.
Old Oct 3, 2012 | 12:30 PM
Pingg's Avatar
Icon5 Re: D16a6 head on d15b6 block??
Don't want to start a new thread for this so i just bought a d15b6 motor and its got a d16a6 head on it but they didn't swap the pistons over. So i want to know would this cause immediate damage upon start up or something that would take time to happen.
Old Oct 3, 2012 | 12:36 PM
24TEN's Avatar
PHANTOM MENACE
Immediate. Think about it, if the piston only accomodates 2/4 valves, would do you think will happen to the 2 valves that don't have relief cuts in the piston?
Old Oct 3, 2012 | 12:45 PM
Pingg's Avatar
That's what i thought but apparently this guy has been driving this car around for least a year like this. So idk
Old Oct 3, 2012 | 12:47 PM
24TEN's Avatar
PHANTOM MENACE
You sure? Maybe you might wanna verify things for yourself. Or maybe we're all wrong and it's fine to use 8 valve pistons.
Old Oct 3, 2012 | 12:59 PM
Pingg's Avatar
Yeah i took a look at the pistons and there stock. I even heard the car start before i bought it and it sounded fine so didn't think anything of it till i took a closer look but **** i guess if it ran fine I'll just run it as is and see what happens. I'll Also check what the compression is at when i start it up.
Old Oct 3, 2012 | 01:29 PM
24TEN's Avatar
PHANTOM MENACE
So the pistons only had two valve reliefs each? And he had the head seperated to show you? And you saw 16 valves? And you saw him reassemble and fire the car up?
Old Oct 3, 2012 | 03:13 PM
Pingg's Avatar
Yes only 2 relief valves and no he didn't take it apart and show me he just started it. I took a look at all that when i got back and that's when i realized the pistons were stock and yeah theres 16 valves.
Old Oct 3, 2012 | 03:32 PM
24TEN's Avatar
PHANTOM MENACE
So you took it apart then after you got home?
Old Oct 3, 2012 | 04:13 PM
Pingg's Avatar
Yes
Old Oct 3, 2012 | 04:16 PM
24TEN's Avatar
PHANTOM MENACE
Well maybe you just proved you don't need to swap pistons? Any chance you can take pictures and post them? Any evidence that the pistons are coming into contact with the valves at all?
mon.jar94
May 20, 2013 07:42 PM
bunny6593
Aug 9, 2011 04:04 PM
creepass
10
Nov 8, 2008 11:12 PM
tomlinson619
Apr 14, 2006 04:34 AM
flashedDc5
Jan 2, 2006 08:08 PM
