Mid-Atlantic (Sales) VA, DC, and MD
EK Coupe K20Z3 Engine/LSD Trans Partout
Old Mar 30, 2012 | 08:55 AM
slow sol's Avatar
Default EK Coupe K20Z3 Engine/LSD Trans Partout
Means of contact: 703-789-1655
Price: Varies **IF YOU DONT LIKE MY PRICES, MAKE AN OFFER, OTHERWISE YOU WILL BE REPORTED**
Motor/Trans Has around 24K Miles, Came from a Salvaged Vehicle. VIN #'s are intact.
**MOTOR AND TRANS ARE IN THE CAR CURRENTLY SO IF YOUR INTERESTED IN ONE/BOTH COME SEE AND TEST DRIVE IT BEFORE THE WEEKEND BECAUSE THATS WHEN THE SWAP IS BEING REMOVED***
-1996 Honda Civic Dx------------------------------------$1,500 (for more info its in another thread)
-2007 Honda Civic Si K20Z3 BARE-----------------------
-6 spd LSD transmission--------------------------------
• Hasport EKK1 mounts---------------------------------
• 04 RSX-S engine/charge harness---------------------$150
• EK conversion 4-2-1 race header----------------------
• 2.5 exhaust------------------------------------------$100
• Karcepts RBC intake adapter---------------------------
• 04 RSX-S throttle body-------------------------------$100
• IACV block off plate----------------------------------
• Hybrid Racing fuel rail---------------------------------$125
• B&M fuel pressure gauge------------------------------$20
• AEM fpr----------------------------------------------$100
• HR Braided fuel line conversion kit---------------------$200
• Walboro 255 fuel pump--------------------------------
• Hybrid Racing Speed sensor conversion----------------$150
• Hybrid Racing EK conversion harness------------------$250
• Hondata K-pro ECU (PPA)-BASE MAP -----------------
• 07 Civic Si shifter/shift cables------------------------$200
• Drive Shaft Shop 600hp rated conversion axles--------
• Griffin Auluminum racing radiator for EK conversion-----$250
• Dual slim fans----------------------------------------
-Hybrid Racing AC Kit----------------------------------$300
-Coolant Hose Adapter---------------------------------$25
-RBC---------------------------------------------------
-Karcepts Shifter adapter--------------------------------$100
-Clutch line----------------------------------------------$60
-Starter-------------------------------------------------
-Alternator-----------------------------------------------
-EP3-----------------------------------------------------
-Primary O2 Sensor---------------------------------------$100
Here is The VIn That I ran To Show The Motor Is LEGIT!
Results for VIN: 2HGFA55537H709506
Print this Page
VINCheckSM Theft Record
2HGFA55537H709506 has not been identified as a vehicle listed in the VINCheckSM Theft Records.
VINCheckSM is updated regularly as additional information is reported.
VINCheckSM Total Loss Record
Further information is available through AutoCheck .
VIN: 2HGFA55537H709506 has been identified as a vehicle listed in the VINCheckSM Salvage Records.
Date of loss: 2008-03-09
Cause of loss: Collision
You are advised to consult with a certified automotive technician before further considering this vehicle, to include verifying the airbag remains intact.
Propulsion
Oct 2, 2016 09:00 PM
Alexander Ulber
Mar 26, 2016 05:17 PM
vmolla1
Jun 3, 2013 07:08 AM
topogon
Transmission & Drivetrain
Aug 7, 2010 05:20 PM
Dena23
Aug 25, 2007 05:28 AM
