rear disc swap conversion questions.
Old Mar 29, 2012 | 04:58 PM
john89crxsi's Avatar
Default rear disc swap conversion questions.
i have an 89 crx si with DA teg, front and rear brake conversion, using the da prop valve, and ef sedan master cylinder.. my question is what acables should i use? the da cables are about 4 or 5 inches too long...
Old Mar 29, 2012 | 05:52 PM
sirtef9's Avatar
Default Re: rear disc swap conversion questions.
The e brake cables from the da should be fine, must not have them routed right.
Old Mar 30, 2012 | 06:12 AM
TeamRedline89Hatch's Avatar
The DA cables are a little long on the CRX but they will work just fine. If you want more proper fitting ones, get cables from a 90 or 91 CRX Si.
Old Mar 30, 2012 | 08:12 PM
tyvtec23's Avatar
DA rear disc conversion are to long for Ef civic, crx, and eg hatches, they work well with coupes but for some reason no hatches, he's right get the 90 or 91 crx Si ebrake cables they fit perfectly of course
Old Mar 30, 2012 | 10:13 PM
AyO Deebo's Avatar
Old Mar 30, 2012 | 10:52 PM
asianflava's Avatar
I was told that the cables from a 2-dr DA fits a hatch, and the 4-dr DA are long for a hatch. Both are long for a CRX. I bought a set of DA arms and it fit my hatch, including the cables.
Can't say about fitting cables on a CRX because mine came with rear discs from the factory
pnapolitano29
Nov 26, 2014 08:58 PM
ZCHondaCRX91
Dec 4, 2011 03:03 AM
BoostThisMS
Aug 8, 2011 04:37 PM
kidicarus425
Jul 18, 2008 05:00 PM
jrthecow311
Feb 1, 2003 10:40 PM
