offset help 15x8
Old Mar 29, 2012 | 06:50 AM
sosxbmx's Avatar
Default offset help 15x8
i want to run a 15x8 on my 95 civic but i have no idea what kinda offset that i need to be somewhat flush.
Old Mar 29, 2012 | 01:45 PM
KandabashiDevil's Avatar
Default Re: offset help 15x8
Sedan, hatch, or coupe?
Old Mar 29, 2012 | 08:33 PM
rosskn90's Avatar
if it helps i ran 15x8 +15 on a integra i had to roll the fenders.... and dont dump it... lower it but keep it at a moderate height..
Old Mar 29, 2012 | 09:19 PM
toyomatt84's Avatar
Sanji
A +35 offset will require either some negative camber or a quality fender/quarter panel roll to fit properly sized tires.
Old Apr 2, 2012 | 02:26 AM
sosxbmx's Avatar
Its a coupe a nice set of coilovers is coming to help with height , but i wouldnt bitch about being factory height as long as i can get away with some wider wheels and tires, im not worried about rolling some fender wells thats cake walk, thanks everyone thats responded so far
Old Apr 2, 2012 | 04:55 PM
rosskn90's Avatar
yeah because i dropped my car 2.5 in the front and 2.25 in the rear and rolled fenders and i really couldnt have anyone in the car... haha i did it once and wanted to cry... so a solid 1.5 should be ok i want to say
Old Apr 2, 2012 | 05:09 PM
jserman's Avatar
nothing less then +20
Old Apr 7, 2012 | 01:16 PM
sosxbmx's Avatar
ok ive found a tire and i believe i can run a 225/50r15 on a 15x8 with about a 32+ offset sound about right guys?
Old Apr 7, 2012 | 02:45 PM
toyomatt84's Avatar
Sanji
That should work with minor body modifications.
Old Apr 8, 2012 | 04:47 AM
ChristianL's Avatar
Not sure how much different the EG is from the EK, but I just put 16x7 wheels with a 42 offset and 205/45-16 Khumos on my stock suspension-equipped '97. They fit pretty nicely, and are just about flush with the fender edges. No rubbing issues, either.
Old Apr 8, 2012 | 12:37 PM
sosxbmx's Avatar
awesome thanks for the help everyone! ill post pics when i get them mounted
Old Apr 14, 2012 | 07:53 PM
Sik Eg's Avatar
I'm doing a 15x8 rim with a 195-45-15 tire will let you know how that turns out. Last year I had the Konig Kandys in a 15x7.5 I had a 205-50-15 on it and they where good but they rubbed so I'm trying something new this year good luck with your setup
Old Aug 6, 2013 | 10:03 AM
mikesanto70's Avatar
What was the offset, because 15x7.5 with a 195/45/15 should not have rubbed unless you had a ton off off set like a 0 offset or +10 with a =25 or =35 you should have been fine, do you know what the offset was?
+25 +35 offset for above post
NA Is Best
Honda Civic (2001 - 2005)
Jul 11, 2019 05:06 PM
pinoysi2000
Mar 24, 2013 02:01 PM
candy eg
Feb 23, 2010 08:17 AM
JDM_902
Oct 15, 2008 08:14 AM
hplssone
Jan 6, 2008 02:14 AM
