FS/FT: Mild Built B18c5 Full Swap with Tons of Aftermarket Parts
Old Mar 29, 2012 | 06:45 AM
watisjdm's Avatar
Icon3 FS/FT: Mild Built B18c5 Full Swap with Tons of Aftermarket Parts
Means of contact: Pm or text 919-218-0546
Price: $6,000 obo
Description: I have a mild built b18c5 with alot of aftermarket parts here is the full list of what with come with it
Bottom End:
B18c5-rebuilt
OEM P73 Pistons
Shot peened P72 rods
ACL Race bearing kit
mircopolished and balanced crank
OEM honda waterpump
OEM Type R Oil pump
ALL NEW OEM Gaskets and such
Hondata Intake manifold gasket
ARP B18c5 Head Studs
Head:
2000 JDM Type R -(378 miles on it)
Rev Racing dual valve springs
Supertech Retainers
Skunk2 Stage 2 Camshafts
OEM 3 layer headgasket
skunk2 cam seal
Black Works Racing Purple Cam Gears
RLZ RACE Valve Job and P&P
OEM HONDA Type R Valves
OEM Timing belt
Benen Polished Fuel Rail
Skunk2 Pro Series Intake manifold Portmatched to 68mm
Professional Products 68mm TB
RC 310cc Injectors
3" Injen Short Ram Intake
Tranny: 2001 ITR Transmission with VIN
Brand New OBX LSD (0 miles, Rebuilt)
fidanza 7.5lbs flywheel
ARP pressure plate bolts
ARP flywheel bolts
Exedy stage 1 Clutch kit
ETC:
Innovative Custom Purple With Black Insert (65a) Billet EK Mounts
99-00 Honda Civic Si Shift Linkage with Energy Supsension Bushings
Skunk2 Dual Bend Shifter
Downstar Inc Full Engine Bolt Kit
Downstar Inc Transmission To Engine Bolt Kit
OBD2A ChaseBays CM1 Engine Harness
Im sure there is more I will edit and add it if I find something else, I can also take more pictures if needed
watisjdm
Jun 24, 2012 05:51 AM
watisjdm
Jun 20, 2012 08:51 AM
watisjdm
Jun 8, 2012 07:10 AM
watisjdm
Mar 29, 2012 09:19 AM
SPL Dan
Jan 15, 2008 11:10 AM
