Passenger side axle popped out
Old Mar 29, 2012 | 12:59 AM
cagedGSR's Avatar
Default Passenger side axle popped out
Hey guys, I'm new here, Just picked up my 96 GSR a few days ago.
I was driving around eating up some corners rather quickly, getting to know the car. I came up to a sharpish corner that has a dip in the middle. I downshifted to third and let the clutch out, at the same time I hit the dip and the apex of the corner. The car died to idle and I had NO clutch. No gear would engage either.
Long story short, I managed to somehow separate the pass. side axle from the trans. Is this normal? Obviously I've never seen it happen, I even searched here a little bit but no avail.
The car is slammed, to me, on Eibach Coilovers. the front wheels tuck quite a bit. Could it be a combination of cornering along with suspension compression along with torque from downshifting? I was able to jack the car up and smack the axle back in with a hammer. I even put a prybar on it to see if I could pop it back out and I couldn't. Been driving it all day since.
Any help would be great, Like I said, new to Hondas. I'm coming from domestics (swapped 98 SVT Contour) so this import stuff is all new.
Thanks!
Old Mar 29, 2012 | 11:07 AM
cagedGSR's Avatar
Default Re: Passenger side axle popped out
Any help fellas? Car will be my daily driver soon and I'm afraid of this happening again.
Thanks
Old Mar 29, 2012 | 02:39 PM
mouab18c1's Avatar
Could possibly be the wrong axle.
Old Mar 29, 2012 | 03:22 PM
sebTeggy's Avatar
Wtf? How much did it pop out? U just passed the c clip? Was there tranny fluid everywhere? I guess you just undid the c-clip on the end of the axle and it popped out.
Is it a stock GSR? Car wasn't an auto-ls before or anything was it? I have no way of identifying axles, but I guess if you are lowered, then the axle will have a little bit of lateral stress since it has to travel further at an angle, but I'd assume this is negligible.
Sebteggy
Old Mar 29, 2012 | 03:29 PM
cagedGSR's Avatar
The axle appears to be oem. It popped out just enough to lose connection with the diff so the car wouldn't move. Maybe a couple inches from the trans. No fluid leaked out.
It's a stock GSR, vin has dc2 in it. not an auto swapped car.
Any way to figure out if this axle is wrong? measurements or what not? I'm afraid of being stuck on the side of the road again.
I'm wondering if the previous owner didn't pop it in all the way, and that's why it popped out. It sure scared me. I thought I blew the clutch!
Old Mar 29, 2012 | 03:46 PM
B20ztek's Avatar
The clip that sits on the end of the axle that goes into the tranny could be missing, thats what holds it in
Old Mar 29, 2012 | 03:48 PM
cagedGSR's Avatar
When i popped the axle back in I felt it clip, I even tried prying on it to pop it back out but I couldn't.
Old Mar 30, 2012 | 04:12 PM
tegradb7's Avatar
did you happen to be turning right?
Old Mar 30, 2012 | 06:31 PM
cagedGSR's Avatar
Well, possibly. It was an s curve type setup and I can't really be sure where it popped out. But I'm sure it was while turning right
Old Mar 30, 2012 | 06:43 PM
tegradb7's Avatar
That would make sense i think. Engine tend to shift to the left while turning right specially turning hard.. I would check all the mounts.. I've never seen this one happen before also and is very uncommon for the axle to be separated from the tranny but is possible. Gud luck
Old Mar 30, 2012 | 06:50 PM
cagedGSR's Avatar
It has hasport mounts. All solid
b18c1vtecdc2
Feb 13, 2017 10:42 AM
GdmLaz
Jul 11, 2013 03:10 PM
B16RacerN2NR
Transmission & Drivetrain
Jun 11, 2010 11:01 AM
2wheelsmoker
Nov 6, 2006 01:25 PM
b16adohcvtec
May 9, 2005 08:02 PM
