d15b7 bolt torque specs
Old Mar 28, 2012 | 03:30 PM
cvcntn's Avatar
Default d15b7 bolt torque specs
hello all
I am rebuilding a d15b7 engine and was wondering if anyone could point me in the right direction for all the torque specs for the bolts on pretty much everything from the valve cover down to the oil pan and possibly the correct sequences also. thank you.
Old Mar 28, 2012 | 04:42 PM
grumblemarc's Avatar
The Grumpiest
Default Re: d15b7 bolt torque specs
You really need to get a hold of a manual. That's the direction I would point you in. Especially if you're rebuilding an engine.
Old Mar 28, 2012 | 05:39 PM
coolswimmerjon's Avatar
Here is a link to Autozone's guide
http://www.autozone.com/autozone/rep...00c152800616e3
Your engine is probably at the bottom of each list because it covers several years of engines. Just select from the side menu for which area you are working on and it should give you torque specs in the reinstall instructions in each section.
Old Mar 29, 2012 | 09:17 AM
cvcntn's Avatar
Thank you very much for the info.
TNHOTROD
11
Dec 10, 2012 11:35 PM
TNHOTROD
Jul 26, 2005 09:37 PM
Islander
Apr 22, 2003 02:20 PM
Smith Wise
Apr 15, 2003 04:02 PM
memphiss13
Dec 12, 2001 08:21 AM
