LOOSE ALT BELT.....
Old Mar 28, 2012 | 03:04 PM
civicpark81's Avatar
Icon2 LOOSE ALT BELT.....
COULD A LOOSE ALTERNATOR BELT CAUSE THE BATTERY TO NOT FULLY CHARGE? I WILL TEST THE ALTERNATOR BUT WANT TO KNOW.
Old Mar 28, 2012 | 03:09 PM
pityocamptes's Avatar
Default Re: LOOSE ALT BELT.....
NORMALLY YOU ONLY SEE THAT WHEN... (remove the caps lock...) vehicle is sitting at idle and lights, etc drop (especially if you have an ammeter). I would suspect that you would hear squeeling with a loose belt. You more than likely have a bad battery with a shorted cell. Easy way to find out which it is:
Test alternator output with voltmeter - on output stud
Take battery in to store and have them do a load test
Old Mar 28, 2012 | 03:16 PM
Sorry about the caps.....the battey was tested and it tested good. I do hear squealing.
Old Mar 28, 2012 | 03:19 PM
...just busting your nuts... OK, than your belt is loose. I would probably pick up a new set since you will be in there anyways replacing the alt belt. Its probably toast, glazed, stretched, etc.
Old Mar 28, 2012 | 03:34 PM
i may have just gotten the wrong belt.....still trying to order parts for myb20. i got the belt telling autozone itwas a 98 crv.
MyWhiteEJ6
10
Jul 21, 2013 05:44 PM
JAYB90
Jun 9, 2009 12:47 PM
failed
Sep 4, 2005 05:59 AM
mjrage
Jul 4, 2004 01:06 AM
Old Skool
Mar 13, 2003 10:24 AM
