Teg Idle Problem w/ prelude T/Body
Old Oct 11, 2002 | 04:36 AM
HardKore's Avatar
Default Teg Idle Problem w/ prelude T/Body
I bought this 93' prelude throtle body from a friend. He had it put
on his 94' intergra. Anyways we install it and now when my car is
idling my RPMs fluctuate from 1000 to 1500 RPM. I have a
Tannabe Racing Medalion so it's pretty loud and annoying.
I have a 97' integra. I asked my friend about the fluctuation and
he said that it would fluctutate when he first installed it but he said that
after a while it went away. What the deal with this? Is it good
for my engine the way it revs up and down for no reason.
thanks
Old Oct 11, 2002 | 04:43 AM
AW's Avatar
AW
Default Re: Teg Idle Problem w/ prelude T/Body (HardKore)
Reset your ecu and see if it goes away. I had a similar problem when I installed a B18C5 motor in my car and did not reset the ecu. I thought because it was not much different there would be no problems but after I reset the ecu. The idle smoothed back out.
AW
Old Oct 11, 2002 | 10:30 AM
HardKore's Avatar
Default Disconnect the ECU
I already tried that. I tried the throtle body screw adjustment but it did not do anything.
Old Oct 11, 2002 | 12:09 PM
Comp97GSR's Avatar
Default Re: Disconnect the ECU (HardKore)
maybe it is the TPS
AW's Avatar
AW
How long did you wait after you reset it? If you tried the standard procedure of pulling the ecu for 10 minutes, starting it(don't touch gas) and let it idle for like 5- 10 minutes and it still does this then it may be another sensor or distributor.
Old Oct 11, 2002 | 02:42 PM
HardKore's Avatar
Default still idles
When I turn on my car the idle doesn't fluctuate i let it sit there for a while and when i give it gas it just goes
VROOOOOMMMM vrooooooooommm VRRRRRRRRRROOOOOOOM vrrrooooomm etc.
This sux
Old Oct 11, 2002 | 02:43 PM
RegRedTeg's Avatar
mine does the same thing, when I first start it its fine but after it starts to warm up it goes like its about to die out but then comes right back.
avargas28
May 27, 2009 12:22 PM
seths_86_prelude
Jul 30, 2006 05:55 PM
fartknocker
Jun 16, 2005 09:08 PM
turbo Si
Jun 1, 2005 09:07 AM
