My EG won't start help please
You do realise this is an Integra forum, not a Civic one...
Not enough details about the car, what motor? Are you getting spark? Fuel? Does it crank or nothing happen at all?
SEARCH. This has been covered A MILLION time.
Ditto the above^^^ need more info, "My EG won't start" does not mean a lot.
Start with MM&Y of car, I would assume it is a 92-95 Honda Civic, but you know what they say about assuming.
Does engine crank, [starter motor works] and not start, or does engine not even crank, [starter motor not working]????
Also, have you checked to see if you have spark and fuel, [can you hear the fuel pump priming when you turn on thew ign. ? 94
From the FAQ.
No Start Diagnosis Basics
OP, grumblemarc is correct a little time searching should find complete instructions on diagnosing your problem, it has been beaten to death.
Without more information on what you have done all we can do is guess what is wrong and suggest testing this or that, all of which is already out there and very detailed.
You made the first move, you determined there was no spark, so have you checked why, did you check to see if distributor assembly has power when ign. switch is in the run and start position?
So instead of us spoon feeding you, make an effort to search, I know I have gone through it more then a few times. 94
redline7
Jul 16, 2007 08:49 AM
