EJ1 Leaking on Tranny Housing
Old Mar 27, 2012 | 11:15 AM
Blacknight117's Avatar
Icon2 EJ1 Leaking on Tranny Housing
Would anyone be able to tell me where this is coming from? I replaced my valve cover gasket. The distributer O-ring is only a few months old. My coolant level is the same and my oil is still full from an oil change three weeks ago...And my tranny fluid is full..
[IMG][/IMG]
Old Mar 28, 2012 | 08:35 PM
MIEj1's Avatar
Default Re: EJ1 Leaking on Tranny Housing
I basically have the same problem. Do you know exactly where the fluid is leaking from? See if you can trace it to the point where it's built up the most. Could possibly be the internal o-ring in the distributor.
Old Mar 28, 2012 | 08:44 PM
I looked at it today and I was thinking the same thing. I`m going to clean it off tommorrow before work and see if I can where it`s coming from. Hopefully it is just the o-ring..
Old Mar 31, 2012 | 10:32 PM
MIEj1's Avatar
Yeah do that and see if you can find the trace.
Old Apr 1, 2012 | 12:04 AM
Lil Gnome's Avatar
That's an automatic, right?
My trans leaks, but it is obvious it is my transmission leaking because the fluid's red.
Yours looks to be oil. So it may as well be.
Have you checked the distributor area to see if there is a leak, or drip?
Blazinmiller
Aug 31, 2010 08:14 PM
phish4709
Apr 8, 2007 07:51 PM
JDMlyfestyle
Nov 1, 2005 03:59 PM
turbotime
Aug 17, 2004 08:44 AM
