4th Gen Prelude JDM Climate Control Questions??
Hey everyone,
I've searched the web, but can't find a wiring diagram for the JDM digital climate control conversion for a 4th generation prelude. Everything i've found leads back to JRCormier or something like that, but it no longer exsists.
Does anyone know where i can get a wiring diagram?
I've read that the first gen Acura CL sensors can be used, but i can't locate the JDM air mix motor anywhere.
Has anyone found an alternative option for the Air Mix Motor or is the JDM Prelude Air Mix Motor the only option and where can i get one?
here man this should help you out..http://www.honda-prelude.com/knowledgebase/manuals/4
i have an actual copy of the jdm wiring diagram for it but i dont know what i did with it. you should be fine with that link though.
Thanks, that's a lot of help. But none of my sensors have connectors, so a full wiring schematic would be best. And I'm still curious about that air mix motor?
Looking over all my stuff, I dont seem to have a heater core temp. Sensor either and i can't find a listing for One under the acura cl. Any ideas where I could find one of those?
well the air mix motor i think has to the the prelude one. possibly the heater core sensor too. i know a lot of the sensors are interchangeable with the CL like you said. outside temp sensor, sunlight sensor, inside temp sensor, and im pretty sure the evap sensor are all interchangeable with the CL.
henry9419
Aug 1, 2012 10:25 AM
Siegfried
Jan 26, 2005 09:57 AM
