Cleaned IACV -- now car idles VERY LOW
Old Mar 26, 2012 | 07:00 PM
Ju1cesk8er's Avatar
Default Cleaned IACV -- now car idles VERY LOW
I've been having an issue with my car idling low for awhile so I decided to take off my IACV and clean it. I took it off sprayed it with some carb cleaner a couple times and put it back on. Plugged everything back up and what not. Started the car and it seemed okay. After it got warm the idle dropped VERY low. Every time I hit the gas it would rev up and then drop to the point where its about to cut off. Help me! What did I do wrong?
Old Mar 26, 2012 | 07:20 PM
jonesEK's Avatar
Default Re: Cleaned IACV not car idles VERY LOW
mess with the idle screw on the TB
UPSIZE FONT DONT HELP JUST LIKE MY CAPS DONT
Old Mar 26, 2012 | 07:31 PM
Ju1cesk8er's Avatar
Will give it a try.
Old Mar 26, 2012 | 10:09 PM
Arthas's Avatar
Its a flat head.
Old Mar 26, 2012 | 10:15 PM
famous323's Avatar
make sure you let the car warm up fan should come on at least once, unplug the plug for your iacv and adjust the tb screw to your desired idle, plug the clip back into your iacv, pull the ecu fuse in the fuse box located in your engine bay wait 15 seconds so your ecu could adjust/reset for your new idle adjustment, plug the ecu fuse back in and restart your vehicle.
***2nd fix that horrid bold font.
Old Mar 26, 2012 | 11:09 PM
Ju1cesk8er's Avatar
Hahaha sorry guys. I'm new to this lol. But forsure. Will give it a goi the morning.
Old Mar 27, 2012 | 06:35 AM
dpetro1's Avatar
don't just randomly mess with the idle screw. adjust it to the proper setting as famous was describing. also, it would help to know what car you are working on
Old Mar 27, 2012 | 07:47 AM
Ju1cesk8er's Avatar
Thanks. Its a 94 del sol si. I believe its a D16z6.
Old Mar 27, 2012 | 08:58 AM
Ju1cesk8er's Avatar
I followed the steps and its still doing the same thing. I recorded it,I will upload the video now.
Old Mar 27, 2012 | 09:04 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Meh. I had this same problem after I cleaned mine. "Uh-oh" I said, thinking I had really mucked things up. Fiddled with the adjusting screw, still ran like crap. It was late by this point, had to go to bed. Next AM, everything's fine. Drove to work, no issues.
Old Mar 27, 2012 | 09:05 AM
Former User's Avatar
Default Re: Cleaned IACV -- now car idles VERY LOW
Try resetting the ECU.
Old Mar 27, 2012 | 09:07 AM
meandyanyan's Avatar
where is your video?
Old Mar 27, 2012 | 09:11 AM
deschlong's Avatar
Loved
Community Favorite
This too. I believe it's the 7.5A fuse under-hood.
Old Mar 27, 2012 | 09:29 AM
dpetro1's Avatar
where does the car idle with the IACV unplugged? does the idle change when you plug the IACV back in?
Old Mar 27, 2012 | 09:49 AM
Ju1cesk8er's Avatar
Heres the video http://www.youtube.com/watch?v=vNpLU...ruYMvXxz5rU%3D
Old Mar 27, 2012 | 09:52 AM
Ju1cesk8er's Avatar
It idles very low with IACV unplugged like 150-200. With it plugged in it seems to idle fine. but once I give it some gas it drops very low and catches itself. If I can make a better video let me know. I have all day.
Old Mar 27, 2012 | 09:53 AM
Ju1cesk8er's Avatar
I reset it when I adjusted the idle.
Old Mar 27, 2012 | 09:54 AM
Drive around for 20 minutes to see if the idle settles down.
Old Mar 27, 2012 | 10:01 AM
Ju1cesk8er's Avatar
Will do now.
Old Mar 27, 2012 | 11:54 AM
Coupe-R's Avatar
If it idles at 200rpm with IACV unplugged at operating temp with all accessories off then you need to adjust your idle screw just like in the instructions!
You say you followed the steps, then you say with it unplugged it idles at 200.
Thats not following the steps!
make it idle higher
accordmatt
Jan 28, 2013 05:57 AM
Mr. LS VTEC
Oct 25, 2006 05:43 AM
redman223
Jun 26, 2003 08:20 PM
arren123
Mar 27, 2003 11:15 AM
