Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 civic si Dc header CEL
Old Mar 25, 2012 | 06:53 PM
denisq6's Avatar
Default 06 civic si Dc header CEL
so i installed the ceramic dc header and after 4 hrs the CEL came on. how do i get rid of it ? and is there any way i can pass emission test with this since there is no catalyst.?thanks
Old Mar 25, 2012 | 08:11 PM
doood's Avatar
been there done that
Default Re: 06 civic si Dc header CEL
1. get a defouler
2. put the stock one back in when smog time comes around or find a shady shop to pass you
Old Mar 26, 2012 | 04:58 AM
denisq6's Avatar
Thats gna suck because it took me about 4 hours to install this header and id say il never do it again..
Old Mar 26, 2012 | 05:47 AM
denisq6's Avatar
Default Re: 06 civic si Dc header CEL and bad noise?
Ok so after i installed the DC header i didnt notice for a while that there is a hissing or idk what to call it but there is a noise coming from the flex pipe/right by where it connects to the exhaust and its a little loud. could it be the flex pipe?and if it is the flex pipe would i be able to replace it? or could it be the 2.5 header going to a 2.0 piping? or? It has a really nice deep tone its just that noise that idk if its normal.. thanks guys
Old Mar 26, 2012 | 07:27 AM
HRsi-dan's Avatar
Since it's a race header, you can hear the gases passing through the area that used to be the cat. It's normal, but just in case, double check under the car to make sure you don't have any leaks.
Are you going to run aftermarket or filled motor mounts?
Old Mar 26, 2012 | 07:59 AM
MyReasonToSHAME's Avatar
defouler... and your good as for the sound thats normal but check for leaks...
Old Mar 26, 2012 | 10:41 AM
m_shake's Avatar
Get flashpro and turn off the 2nd O2 sensor. You removed your cat and wonder if it will still pass emissions.....your seriously joking right?
Old Mar 26, 2012 | 01:07 PM
denisq6's Avatar
Ok il leave it maybe il get used to the sound but il need a catback soon and then flashpro and i guess il just go to stock header when emissions come then put the dc back on.
da1lydr1ver
Honda Civic (2001 - 2005)
16
Feb 12, 2007 09:03 AM
rewhipple
Apr 6, 2005 09:22 AM
thanatos2k
Jul 15, 2003 10:15 AM
3700 Vtec
Mar 24, 2003 07:38 PM
dynomite55
Sep 7, 2001 12:07 PM
