Tranny cant make up its mind!
Old Mar 25, 2012 | 03:06 PM
Shinghi's Avatar
Default Tranny cant make up its mind!
Hey all,
So heres the issue ive got. My tranny while driving around the city cannot make up its mind when in 3rd gear to either shift into 4th or to do the neutral thing (OD? I dont know what it is called), so instead it kind of just locks up in 3rd and slows the car down, doesnt cruise (all of this when releasing the gas). Im wondering what could be the issue - ?? Any ideas. When im in D3 ive got no problem it just goes into neutral.OD when i release the gas.
Here is a better picture
D4
City Driving - 20 - 40 mph
1st - 2nd - 3rd ---????? 4th or OD no wait just 3rd - slowed
D3
1st - 2nd - 3rd - OD/Neutral no problem
Thanks guys and gals
Shinghi
Old Mar 25, 2012 | 06:41 PM
(. )( .)'s Avatar
Default Re: Tranny cant make up its mind!
And what year is the car? Any check engine lights?
Old Mar 25, 2012 | 06:55 PM
Klasse's Avatar
Thread title is funny. Sorry no help other than that
Old Mar 25, 2012 | 08:06 PM
Shinghi's Avatar
1995 honda accord ex auto sorry !
Old Mar 26, 2012 | 08:45 AM
Roader's Avatar
The FSM shows these 3→4 shift points:
  • TPS 0.8v (closed throttle): 29 - 33 mph
  • TPS 2.25v: 54 - 59 mph
  • TPS 4.5 (full throttle) 93 - 98 mph
If you're going 35mph, not touching the gas, the transmission stays in 3rd gear and won't shift into 4th (OD)?
Old Mar 26, 2012 | 11:08 AM
Shinghi's Avatar
Thanks roader, so i should release the gas between 29-33 and i should be fine right.
or do you think it is better to just be in D3 when cruising around town? will that sacrifice gas mileage?
Old Apr 16, 2012 | 01:14 PM
Shinghi's Avatar
So I pinpointed when the "catch" occurs and it is while in 3rd between 25-28.9 mph.
The same catch does not happen when in d3.
Any ideas? VSS? Linkage cable? Some sensor?
Old Apr 16, 2012 | 08:23 PM
MAD_MIKE's Avatar
MM Gruppe B
With city driving there will be more changes in speed and less likely an ability to maintain a high steady state speed, with it in D4 it will try to upshift when you are cruising, this is most likely the hunting you are feeling. Leave it in D3 and the transmission will not try to constantly upshift.
If I can maintain a steady state speed of 35+MPH I put the trans in D4. If I know I'll be doing more throttle modulation/braking stuck in traffic, I leave it in D3.
otisvillain
Nov 20, 2013 03:31 PM
mrwink
Sep 3, 2004 04:11 PM
kidd11
Jul 13, 2004 07:20 PM
LsBoy
Nov 12, 2003 01:27 PM
