View Poll Results: Which size would fit better?
18x8 +35mm
0%
18x7.5 +45mm
0%
Voters: 0. You may not vote on this poll
Acura RSX Type S - Help me figure out which wheel would fit better.
This car is a 2005 Acura RSX Type-S.
I have figured out which wheel I would like to have. I am most likely going to buy the:
Model = TSW Nurburgring
Size = 18inch
Bolt = 5x114.3 5 Lug
Color = Gunmetal
That is the correct bolt pattern, correct?
I have two choices for diameter and offset:
Offset: +35mm
or
Offset: +45mm
Which size would fit better? Would it even matter?
If it doesn't matter I will get the wider 18x8 +35mm.
I appreciate your help.
Size = 18inch
Color = Gunmetal
Offset: +35mm
or
Offset: +45mm
You should be fine with either wheel. And, you could run a 215/40/18 on either (which would be the safest tire choice for either wheel).
