$$$Need info on engine$$$$
i have a 93 coupe with a b20 engine, non vtech. i dont know too much on engine. if i go to the autoparts store what year and model do i ask for parts for. i know its off a crv but not year or model, fwd or 2wd??? any help is appreciated.
depends what parts you're looking for. check the front of the block for a small flatspot that should say what b20 it is, given you haven't changed the head. google that and i'm sure youll get info on what crv it came out of.
although, if your sure its a crv b20, its probably from a 95-01 [first gen]. after that they put the k24's in the crv's if im not mistaken.
full info off block is " b20b1090779 ". just general parts like oil filter, a/c system if i want to readd it, thermostat, alternator, belts stuff like that.
Any parts you get should really be identical to an integra or any FWD CRV.
You definitely wouldn't get 4WD axles, would you?
It's a b-series engine, it uses b-series parts just like a b16 and b18 share parts.
