DA6 integra alternator not charging battery and speedo not reading
right i have a da6 integra 1990 which had a zc motor in it which has had an engine swap to d15 i think the alternator wont charge the battery and the speedo wont read, any help ?
Alternator could be going out, cables loose or corroded, battery could be bad, alternator plug could be loose, and check to see if your speed sensor is plugged up, if it is, then you need a new sensor.
ive tried four different batteries and ill check the cables where is the speed sensor ? were the speedo cable goes in to the gear box?
GPC91
Oct 3, 2012 03:46 PM
