oil pan gasket if exhaust is welded
Old Mar 24, 2012 | 11:27 AM
OSPF's Avatar
Default oil pan gasket if exhaust is welded
Everything from where the A pipe connects to the cat and back is entirely welded on by the previous owner. What's the best way to approach this? If I undo the first set of hinges that hold the exhaust up will it come down far enough so I can remove the oil pan? The welds look kind of brittle don't want anything to crack and cause a bigger problem. Car is a 92 accord.
Old Mar 24, 2012 | 11:35 AM
AccidentproWn's Avatar
Default Re: oil pan gasket if exhaust is welded
it sounds like that's you're only option. Just be prepared if you do have to get it rewelded.
Old Mar 24, 2012 | 11:46 AM
OSPF's Avatar
I've never welded anything in my life but I have JB weld on standby.
Old Mar 24, 2012 | 08:12 PM
you can take it to a muffler shop. I would imagine it wouldnt cost more than 25-50 bucks.
craiggibson21
Aug 14, 2016 10:31 PM
jbrennen
Acura TL, RL & ZDX
Mar 18, 2016 11:46 AM
j894
Mar 21, 2014 02:11 PM
mohater
Jul 30, 2013 01:09 PM
floriudabrain
Sep 4, 2008 02:37 PM
