Idle fluxuation. How to fix?
Old Oct 10, 2002 | 09:16 PM
OneThirtyEight's Avatar
Default Idle fluxuation. How to fix?
Ive been getting some idle fluxuation from about 700rpm-2000rpm when the car is first started, and this will continue off and on even after the car is warmed. What might/probably is causing this? Any suggestions would be very helpful. Thank you.
-Matt
Old Oct 10, 2002 | 09:20 PM
vtec.dc2's Avatar
Default Re: Idle fluxuation. How to fix? (97blackteg)
is it a stock ecu?
Old Oct 10, 2002 | 10:12 PM
Ferrell's Avatar
Default Re: Idle fluxuation. How to fix? (vtec.dc2)
plugs, wires, rotor and cap?
Old Oct 11, 2002 | 03:21 AM
Rory Breaker's Avatar
Fast Idle Thermo Valve under the Throttle Body. Pull off your intake and while the car is running, cover up the upper left-most hole on the inside of the TB with your finger. If the car dies down and sputters, thats it.
Pull it out (3 10mm bolts) and wrap the top of it in duct tape or duct tape some vinyl. Pop it back on and see if that works...
Old Oct 11, 2002 | 06:00 AM
ragejed's Avatar
Default Re: Idle fluxuation. How to fix? (newgsrdriver)
Vacume leaks?
Old Oct 11, 2002 | 08:22 AM
tachman's Avatar
I'd have to agree with newgsrdriver. Same thing happens in my CRX, and I was just told by a Japanese auto shop that it is the Fast Idle Valve.
Old Oct 11, 2002 | 11:12 AM
Default Re: Idle fluxuation. How to fix? (tachman)
Thanks, Ill try that. By the way, what is the nipple on the bottom of my throttle body for? I think its like a t a 90 degree angle? It does not have a hose connected to it. (Probably should )
Old Oct 11, 2002 | 11:17 AM
Muad'Dib's Avatar
Corr Performance Pilot
you might also want to check you the Idle Air Control Valve. If it's ditry then this iwll cause your RPM's to fluctuate like this. HTH.
Old Oct 11, 2002 | 11:24 AM
Default Re: Idle fluxuation. How to fix? (MouhadIb)
Is that the thing on the back of my intake manifold that coolant goes in and out of?
Old Oct 11, 2002 | 12:51 PM
GSRaCeRbOI's Avatar
check the Fast Idle control Valve/ Idle Air Control valve... my roommates car did this and he had an exhaust on it so you could hear it go up and down.. people would look at him funny thinking he was trying to rev it up and down on purpose in the parking space hahaha...
Old Oct 11, 2002 | 02:54 PM
SxyMtch's Avatar
Default Re: Idle fluxuation. How to fix? (GSRaCeRbOI)
My car does the exact same thing... so let me know if any of those suggestions resolves the problem.
-Thanks
Old Oct 11, 2002 | 03:49 PM
IC x Prince's Avatar
New User
Default Re: Idle fluxuation. How to fix? (SxyMtch)
try adjusting your TPS...I had to modify the screw to lossen it, but that's what fixed mine.
Old Oct 13, 2002 | 01:57 PM
Newman's Avatar
New User
Do the simple things first... clean your IAC and purge your coolant when the car is warm. That'll usually fix the problem.
Old Oct 20, 2002 | 09:14 PM
Muad'Dib's Avatar
Yeppers.
Old Oct 20, 2002 | 09:50 PM
sic2kSi's Avatar
Did anything work yet? Cause mine just recently started doing this as well.
[Modified by juz1badLS, 6:50 AM 10/21/2002]
Old Oct 21, 2002 | 12:52 PM
zilverz's Avatar
Default Re: Idle fluxuation. How to fix? (juz1badLS)
ahhh Jville B18B representin ... wassup boss ...
yea my B18B has fluxating idle as well ... ive replaced IAC and FITV with brand new ones .. and adjusted idle air screw ... no gasssssssssssssssss ... i have an auto too ... so when it revz to 2k ... i just turn the AC on to make it drop down below 1500rpm so i can put it in reverse without doing a High Rev drop on the tranny
I hydrolocked the motor a long time ago ... dont know if the water warped anything in the throttle body... but Im about to replace the whole throttle body with a bored one with a recalibrated TPS ... and ill take it from there ... i needed the upgrade anyway
Da9austinRacing
Jul 24, 2011 07:22 PM
okkritikos
Dec 17, 2010 03:22 PM
g0tgot
Feb 1, 2009 07:27 AM
z1p
Oct 15, 2004 01:54 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
