distributor swap s with si
Old Mar 23, 2012 | 07:20 PM
splashy's Avatar
Default distributor swap s with si
okay so I have two del sols, a 93 and 95 both S models. Now the distributor on the 93 went bad, so I put the 95 distributor in it because I only drive the 93 right now. The problem is I got a used distributor to put in the 93, but I guess it turns out it is from a 93 si model (D16Z6). I figured it was the same, both of my del sols have a D15B7, but it turns out the ears don't line up exactly right. Is there anything I can do to attach it, even just to see if it works. I can't return it, I also thought I could at least try to swap the coil and ignitor, but it has a striped screw so I can't even open it.
Old Mar 23, 2012 | 08:12 PM
JDM_teh_WIN!!'s Avatar
Default Re: distributor swap s with si
I don't really understand what your saying but the S and Si coil and ignitor are the same for a 93.
AVgirl
Sep 27, 2010 10:49 AM
Mugenkid
Apr 17, 2008 07:18 PM
HondaVTEC93
Jul 11, 2004 07:18 AM
egNYC
Dec 19, 2002 08:49 AM
