K20z1 in 93 eg coupe
Old Mar 23, 2012 | 04:00 PM
d.whiz's Avatar
Default K20z1 in 93 eg coupe
Has anyone done this swap I need information about doing it pm me or reply to the thread
Old Mar 23, 2012 | 04:11 PM
doood's Avatar
been there done that
Default Re: K20z1 in 93 eg coupe
no. nobody has ever put a k series in a civic.
Old Mar 23, 2012 | 04:15 PM
d.whiz's Avatar
I know people have done k swaps man but if you do searches for this particular k motor in to this eg coupe I found not would you know where I can find info or you just messing with me?
Old Mar 23, 2012 | 04:25 PM
doood's Avatar
what info are you looking for? it's not any different than swapping any other k motor.
Old Mar 23, 2012 | 05:25 PM
d.whiz's Avatar
That's what I thought it should be like any other k swap.
Here's what I have so for the swap,
complete K20z1 starter , fuel rail etc.
Axles
drive shaft axle
engine harness
tranny
I know I will need kpro and conversion harness
I contacted hondata trying to get info about kpro told them the type civic the motor is going into there saying with my car and the k20z1 engine harness will not work there saying I would have to get a 02 to 04 engine harness because the 05 to 06 harness that came with my motor will not work.
Also they said I would have to change the tranny to 02 to 04 because the speed sensor on the 05 tranny from my motor will not work with.
I wanna know if this is true or not I have going thru multiple threads haven't not seen this motor swap done with my car this is why I'm asking.
Old Mar 27, 2012 | 10:35 AM
crazydominicanman's Avatar
You honestly believe a representative from Hondata would straight up lie to you?
Old Mar 27, 2012 | 10:56 AM
d.whiz's Avatar
well is that true or not do you know
Old Mar 27, 2012 | 11:57 AM
TypeRMOBBiN209's Avatar
http://www.k20a.org/forum/
you can search for it here
Old Apr 2, 2012 | 11:10 AM
crazyjetsfan22's Avatar
There are plenty of threads covering this on many of the forums.
I am putting a k20z1 motor and trans into my ek.
They suggest using a 02-04 engine harness for the easy with kpro
you can use and 05-06 engine harness but it will complicate things
You can use the 05 trans no problem you will need to wire a speed converter so that your cluster will work.
Hyrbid racing sells one
poseghatch
Apr 5, 2013 06:32 PM
sirb16a
Honda Civic (2001 - 2005)
Mar 2, 2010 09:33 PM
BlackAlbumKoupe
Dec 7, 2009 09:44 AM
BLUE EH3
11
Jun 28, 2004 05:16 PM
