D-series vss with B16a?
Old Mar 23, 2012 | 03:22 PM
Shadowcat's Avatar
Default D-series vss with B16a?
ok so my spedometer just spazzes out and bounces around but will sometimes kinda work. so i got a d series vss but i dont know if it will work with the 2 bolt vss i have in the trans now.
[IMG]<a href="http://www.flickr.com/photos/69121561@N02/7009623023/" title="2012-03-23_17-10-24_351 by Shadowcat95, on Flickr"><img src="http://farm8.staticflickr.com/7181/7009623023_a88b2bdd0e.jpg" width="500" height="282" alt="2012-03-23_17-10-24_351"></a>[/IMG]
[IMG]<a href="http://www.flickr.com/photos/69121561@N02/6863505698/" title="2012-03-23_17-10-02_971 by Shadowcat95, on Flickr"><img src="http://farm8.staticflickr.com/7262/6863505698_f9baed5959.jpg" width="500" height="282" alt="2012-03-23_17-10-02_971"></a>[/IMG]
Old Mar 23, 2012 | 03:29 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: D-series vss with B16a?
help you out there
Old Mar 23, 2012 | 04:12 PM
Shadowcat's Avatar
sweet thanks lol still learning
Old Mar 23, 2012 | 06:29 PM
b20c's Avatar
it will work without being bolted up if u needed it to lol. i used an auto obd-2 accord electronic vss in a b-series cable ls tranny (to run a newer guage cluster) with like one ear cut off. the ten mm bolt cocked and only like three threads in and it works perfect. u can use any vss bro just not a obd-0 cable one unless u want a crx si cluster lol. just stick a ten mm in one of holes its not gonna line up perfect but the bolt should go in jus a little cocked then tighten up jus a lil dnt break it. it wont go nowhere and will work just fine. idk it might throw your speedo off a couple miles per hr. but not sure. hope that helps bro. no vss=no vtec
Old Mar 24, 2012 | 10:16 AM
Shadowcat's Avatar
thanks!!
do i need to switch the gears over from the b series to the new d one?
Old Mar 24, 2012 | 10:43 AM
Shadowcat's Avatar
alright. just swaped them out gears and everything. and the d series acually lined up to one of the bolt holes. anyways, drove it and the same damn thing as before just bounces around all stupid. any ideas how to fix this? its starting to **** me off lol.
Old Mar 24, 2012 | 11:44 AM
Technical Hero
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-civic-speedometer-fix-2792878/
Lil Gnome
Mar 1, 2009 12:37 PM
tihz_wa
Dec 11, 2006 10:06 PM
hndakd
Jan 29, 2004 08:03 AM
4inspeed
Jun 3, 2003 03:24 PM
