PM7 Stamped All Over ZC What ECU To Use
Old Oct 10, 2002 | 08:49 PM
ScottEK's Avatar
Default PM7 Stamped All Over ZC What ECU To Use
If the ZC block has PM7 stamped all over it and on the cam gears and everything can you still use a PM6 Si ECU? Could this be causing my code 4 or do I just need to break down and buy a distributor?
Old Oct 10, 2002 | 08:53 PM
Bgladfelter's Avatar
Default Re: PM7 Stamped All Over ZC What ECU To Use (beta13)
how did you wire the dist? Code 4 is for the CYL/crank sensor. Might just be a wiring criss-cross.
You can use either ECU, mines run off of both, but the Teg one feels better. It has more revs to it for the occasional race.
Old Oct 18, 2002 | 10:21 PM
blackEF's Avatar
Default Re: PM7 Stamped All Over ZC What ECU To Use (Bgladfelter)
i have the pm6 which is the crx si ecu....failed emissions with it so i'm not sure how much of a difference it makes to have the right ecu.
Old Oct 19, 2002 | 08:21 AM
B17CR-X's Avatar
You can use a PM6 (88-91 Si ecu)
You can use a 88-89 PG7 (88-89 teg ecu )
And if you can get one imported from Japan a PM7 ecu
re-check your distributor wiring for the code problem.
-Joel
alwaystootall
Mar 2, 2009 08:03 AM
91hatchnewb
10
May 17, 2003 12:26 PM
zccrx
Apr 1, 2003 08:40 PM
REDBARON
Oct 15, 2001 06:21 PM
