1990 accord help!!!!!!
hey i have a 1990 accord lx that idles crazy (up and down) im not sure what it is, ive been told it could be the tps, but know one knows for sure. also speedometer is not working and would like to kno how to fix that issue and if that might be connected to the idle issue.
any help would be greatly appreciated
Thanx.
Thanx.
Fast Idle Valve-open it (2 phillips screws) and turn it all the way down with a flathead. Idle Air Control- remove from intake manifold (2 or 3 12mm bolts) clean it, replace it or block it off. As far as the speedometer, change your Vehicle Speed Sensor that sits on top of the transmission in the area under your thermostat housing.
justinsbg
Jan 17, 2017 11:43 PM
vinspe
Mar 26, 2014 03:16 PM
SlackerAccord
Sep 22, 2005 08:49 PM
