tachometer not working 94 eg hatch
Old Mar 23, 2012 | 07:16 AM
amores213's Avatar
Default tachometer not working 94 eg hatch
Hello, I just did a ls swap out of a 2000 teggy on my 94 eg hatch and the tachometer isn't working . The ecu I used is from a 94 ls. Need help. Thank you
Old Mar 23, 2012 | 09:27 AM
stompbox's Avatar
Default Re: tachometer not working 94 eg hatch
first off pop it out make sure its not just a connection issue then use a multimeter on the wire locations to make sure all are generating power, do the easy possibilities first.
Old Mar 23, 2012 | 09:42 AM
amores213's Avatar
What I've been told to check it the blue wire running from the distributor to the driver side firewall but then I also heard '00-01 teggys are missing that tach wire going to the driver side firewall .it needs to be added. I just need confirmation. before I do it.
Voltage johnson
Feb 16, 2017 10:39 PM
Mac2118
Appearance Build Threads
77
May 18, 2016 04:56 AM
CRXguy_88
Jan 25, 2014 05:27 AM
flanders43
May 7, 2008 05:08 PM
