Obd0 Rex and obd2 sohc Zc
Old Mar 23, 2012 | 07:08 AM
Gremlin_rex's Avatar
Default Obd0 Rex and obd2 sohc Zc
Have tried searching and no luck. I have a harness that was converted to mpfi. Also have the pm6 ecu and injector box. What all is required to go obd1 with the car and obd1 with the motor to match up? Or what would be the best way to do it. Any help would be greatly appreciated. On a major time crunch
Old Mar 23, 2012 | 08:00 AM
KINGVEM^^ED6's Avatar
Default Re: Obd0 Rex and obd2 sohc Zc
Put a pm6 88-91 intake and exhauat manifold on your motor obd2
And just run the car obd0
I have a y7 In my hatch with pm6 ecu and intake manifold
Old Mar 23, 2012 | 10:27 AM
That's it? That sounds way too simple. I don't need any jumper harness's or anything? And u said intake and exhaust manifold on your motor obd2. What were u referencing obd2 to?
Old Mar 23, 2012 | 10:32 AM
Or swap out distributors ? The engine harness i have was made by mono tech and was made for the obd0 sohc Zc. Does that throw a killer in it?
Old Mar 23, 2012 | 11:32 AM
Too run your motor obd0 with the pm6 ecu u will need a 88-91 civic/crx si.dizzy
You can use the si intake.manifold.n.exhaust.manifold
Since ur harness.is.already mpgi that's all brah
Old Mar 23, 2012 | 12:24 PM
Thanks a mil. Man
CBEengineering
Apr 12, 2010 06:33 PM
CBEengineering
Southeast (Sales)
Apr 12, 2010 06:32 PM
sublimeh215
Jan 29, 2010 06:41 AM
DAtegLs
Dec 22, 2009 10:56 PM
deerek101
Feb 5, 2006 09:44 PM
