EP3 16x8 Offset help.
Does anyone know if that set will work? This was my former set up:
Damn trailing arm kept getting rubbed. These Volks are 16x7.5 +35. I want to go wider but that rear trailing arm is tricky, any advice? Make sure you understand that the damn trailing arm on the EP is a factor. Don't answer like it's a 2dr or 4dr Si please.
After thought, I had a 8mm spacer on the rear and didn't have anymore rubbing issues, would a 16x8 work with a 4?+ offset?
+42 with 17.5's
No rubbing
Help anyone?
+42 with 17.5's
No rubbing
Help anyone?
I'm having a hard time seeing what you're trying to ask.
Are you asking if a 16x8 will fit? A +42 can fit, but I'm not sure anything with a higher offset will clearing the rear trailing arm.
What is rubbing against your trailing arms exactly..the tires or the wheels?
Can you post a shot of the barrel sticker or the box showing the size/specs of the wheels?
Like Matt said, I don't see higher offset clearing the trailing arms if the specs you stated do not clear the arms.
I happen to have some 16x8 +35 CEs that we can try on your car and know for sure.
Yeah, that was my question and I wanted to know the offset I'd need to clear that rear trailing arm. There might also be a slight rub on the outer wall of th tire because the rear fenders aren't flared right?
Yeah, the rear quarter panels are a pain in the butt to roll flat, but fitting 8's with properly sized tires is a bit tricky.
Well, 205/50/16's are actually undersized for the chassis, as well as 8" wide wheels. 225/50/16's would be the proper size for both the wheels, as well as the chassis.
The reason I asked for a shot of the sticker of the wheel is because I think you have the offset wrong. I don't think 16x7.5 5x114.3 CE28s were ever offered in +35, so, with the wrong offset in mind, it'll be hard to figure out what will or will not actually clear. GL.
EDIT: I don't have a box shot man, those were my old rims, sorry. I should've done that.
You're saying that because the tire would be over stretched right? I don't know much about tires but I know it's a bad thing when they rip apart, lol.
Well, I'm pretty sure the offset on those CE28s are/were +46 and that would explain why they rubbed against your trailing arm. Member <stevieg> on here has 16x8 +38 rpf1s on his EP with 225s and never mentioned any rubbing issues.
If I had to guess, I'd say anything +42 with *8 and smaller should clear just fine.
I'm just basing these statistics on the wheels you're wanting to run, as well as the proper sized tires for the chassis.
Earthworm Jim
11
Jun 17, 2009 10:01 AM
205/50/16's is what I had on the CE28's. I figured I could run those again.
