Replacing a clutch
I own a 97 Honda prelude type sh an the clutch is going out of it for sure I am wanting to change it asap but I have a problem cause all my other cars have been civics an delsols an I always dropped the tranny out the bottom an changed the clutch but I can't with the prelude best route to do the replacement any advice is much appreciated
same as a civic or integra just disconnect the pass side radis rod I think is what it is goes from the cross member to the lower control arm, and it will squeeze threw there its a huge pain
I did it on my 00 sh lude and several times on the same car when another guy owned it, im looking at it in the honda service manual, remove the down pipe "exhaust pipe a" the center bean and the right radius rod, remove damper forks, atts unit, outer extension shaft, engine stiffner, trans mount bah bah
venger
Jul 2, 2007 12:46 PM
