rsx rype s wiring ecu wiring
My bro just bought an 02 type s. Whenhe was going to get it inspected the guy said his machine couldn't establish a link w the ecu. Were figuring its the kpro. So he sources a stock ecu and when he plugged it up it fired up but died in less then a minute. Looking at the ECU plugs it has 3 wires that were pulled out of the plug. I'm pretty sure I can tell where each wire should go due to length but I'm trying to find a diagram to confirm. I have looked at several but nothing matches. If any can point in the right direction I would appreciate it. Also i checked stickies first and didn't see anything. Thanks in advance.
Also the wires are green/Orange, Orange, and white/red
It's actually a type r ECU. Didn't know that till later on. I got it to work but had to switch the fuel pump pinout from e1 to e10. It runs fine now but still has codes. I've since figured out the wires that are loose are e2 e8 e31. I just need to confirm wire color to hook em back up. I know 2 and 8 are o2 sensor related and 31 has to due w malfunction indicator.
