stage 4 clucth vib and i think starter prob..help
Old Mar 22, 2012 | 09:11 AM
homero's Avatar
Default stage 4 clucth vib and i think starter prob..help
i just built a turbo ready low compreesion SOHC zc block in my 1990 CRX si, i put a xtd stage 4 clucth and flywheel combo also.
driving the car,it shift perfect everytime.
when i put the clucth in to change gears over about 2500 rpm in any gear ,you hear a grinding or vib coming from where the starter is, today the fuse for the starter blowed when i shifted gears.
i parked the car this morning thinking the starter is staying engaged some how,im going to buy a new starter today but was wondering i thought a bad starter is only when the car wont start?? my car starts everytime on the frist try.
has anyone ever have had this prob before or any advice before i buy a new starter??
Old Mar 22, 2012 | 09:20 AM
Dc4LsTeG's Avatar
EK9
Default Re: stage 4 clucth vib and i think starter prob..help
If it starts everytime why are you gonna buy a new starter?
Old Mar 22, 2012 | 09:25 AM
homero's Avatar
because the fuse blew when i shifted gears...i was thinking that some how the starter is staying engaged or engaging when i shift (if that is possible)... i have tryed looking or searching the treads for anything similar with no luck.
Old Mar 22, 2012 | 10:40 AM
homero's Avatar
bump
Old Mar 22, 2012 | 02:23 PM
crvtectim's Avatar
You need to make sure your clutch cable is adjusted properly. I wouldn't dig too deep into popping the fuse. Look for an open to ground in the starter's power wire. If there is one, fix it. If not, no worries. It's an old *** car. I've blown fuses while cruising over railroad tracks lol.
If you know your cable is adjusted correctly, you have an internal transmission problem and it needs to be rebuilt.
Old Mar 22, 2012 | 07:41 PM
homero's Avatar
o.k. i tested the starter...works fine.... i think i did a big no-no when i put the clucth and flywheel in, the little round bearing that came with the kit..i did not put it in becase i did not know where it went..
i put the new clucth bearing that pushes the clucth
then i put the flywheel on the crank with ARP BOLTS
then i put the clucth and disk...
where does the little round bearing go??
yes im a noob
Old Mar 22, 2012 | 09:25 PM
delsol92's Avatar
yes im a noob
it taps into the back of your flywheel in the center, the main shaft in your transmission slides into that so im assuming that when you are shifting that your shaft it moving and crunching **** together, DO NOT DRIVE THE CAR LIKE THAT ANYMORE
robot.reed.o
Mar 11, 2009 06:33 AM
crxaddikt
12
Nov 24, 2008 06:47 PM
pasenast
Apr 14, 2007 04:20 PM
HXvtec
Nov 6, 2004 02:15 PM
Sukebei Oni
Mar 16, 2003 01:21 AM
