Suggestions on adjustable front upper control arms
Car is an 89 hf crx with a b18a1 swap. Knuckles are off a 91 integra.
I've collected all the inner,outer tierods, sway arm bushings etc.. and have a complete set of tokico hp blue struts and tokico lower springs coming. The springs lower the front 1.25 and rear 1.00. I know it will benefit me to get adjustable control arms just not sure what to buy. I'm not fond of ebay stuff but will go that route if deemed best.
My question is....
What do you all use and recommend and where to shop for them.
Thanks in advance!! I'm doing the front end swap next week.
My question is....
Thanks! I continued to read more and it definately appears with the small drop I'm doing that camber is unnecesarry. Orders a new oem set to arrive next week in time for my front end rebuild.
True, with the integra knuckles and a mild drop the camber is fine. Just get an alignment and you're good to go. I do have a set of Revo UCA on the shelf, pm me if you want them.
ihateslowhondas
Oct 18, 2004 06:46 PM
