Honda Del Sol Quarter Panel Repair
Old Mar 21, 2012 | 11:33 AM
habanerored06si's Avatar
Default Honda Del Sol Quarter Panel Repair
Hi Guys.
Well I got myself ****ed over by going with this Arab guy (Considering every Arab I've dealt with was either shady or screwed me over. They'll be added to my list of people not to associate with.) who had sold me on the fact that he could do my Quarters. Said he would be done in a week tops. Well after 8 weeks, $950 and a few phone calls to the police I got my car back.
He didn't fix the rust from behind (which was apart of the deal) and I want to minimize the loss as much as possible in redoing the quarters myself (having to cut out as less as possible...if possible).
Rust I need to access
Area of potential cut
I was planing on making a cut (orange box in picture above.) to fit my hand and my iron bristle brush in their. Apply some hard friction (lol...hard friction..lol) for several hours and then apply anti-rust black paint. followed by some primer (as another sealant? Suggestions on this?). and then finish off with using a 90 degree angel fiberglass form to cover the quarter panel and the inside wheel well.
Any suggestions or advice would be appreciated. Thanks.
Old Mar 21, 2012 | 04:19 PM
salaamq's Avatar
Default Re: Honda Del Sol Quarter Panel Repair
Is there a way to remove it, or are they welded on?
I would cut there anyway and fabricate something with sheet metal, it looks like it has been bondo-ed. I would also fabricate some of the rust you are trying to remove then weld it in.
Looks like your painting that car? If so, keep me posted, i'm gonna need as much advice as i can get on my sol's paint.
Note: I'm arab.
Old Mar 21, 2012 | 08:21 PM
Note: I'm arab.
Sup bro.
Well. I listen to life experiences. Especially the one that occurs frequently and unfortunely I've made a decision. However, I'm respectable towards all.
Anyways. Thanks for the reply. I was thinking the same thing just wanted a second guess.
Your sol's paint? Look at the Tremclad/Rustoleum $50 paint job thread above. I plan on experimenting this way. I wanted a Panda sol and white comes out great this method.
Old Mar 23, 2012 | 02:13 AM
Disease's Avatar
I would get a whole new quarter if I were you. The whole wheel lip looks messed up. And with that huge amount of rust on the bottom there, you are going to need a much bigger section to fix the rust behind it. If you don't fix what is wrong behind the quarter, you will not be able to fix what is wrong on the out side. Can't weld to rust.
Old Mar 25, 2012 | 09:33 AM
simon1211's Avatar
IM A PIANTER AND BODY REPAIR, FIRST CUT THE RUST OUT OF THE WHEELWELL AND THE 1/4 PANEL THEN WELD IF YOU WAN TO DOIT RIGTH A PIECE OF SHEET METAL ON BOTH WHEELWELL AND 1/4 PANEL, GRIND OFF BRUSH SOME RUSTOLUEM SONE KITTYHAIR FIBERGLASS SMOOTH IT OUT PRIMER PREP AND PAINT. OR GET A HOLE NEW 1/4 PANEL
Old Mar 25, 2012 | 09:36 AM
simon1211's Avatar
if you dont weld you could use rivets or sheet metal screws just cut the tips out after screw in them
Old Mar 25, 2012 | 02:18 PM
salaamq's Avatar
Eh, just replace the whole panel. If you can find one. That thing is shot.
I wouldn't think screws or rivets would hold up too well....
Old Mar 27, 2012 | 01:15 PM
Equol's Avatar
i need new quarters on my sol also, where can i get some?
Old Mar 27, 2012 | 07:30 PM
Yea I know D. I've experiemented already in Grinding, using a iron bristle brush and some anti-rust paint. I'm going to give it two weeks and see how it holds against the elements.
I got new quarters coming. If my first attempt doesn't work, then I'll just weld in new sections.
I'm taking this on as a learning process.
Thanks for the advice Simon.
Yea if this doesn't work out. I'll just re-do.
I bought mine off of a member here. fixmyrust.com does not sell Honda Del Sol quarters.
Old Mar 28, 2012 | 03:49 PM
salaamq's Avatar
we NEED a supplier for some new quarters. (other than the dealer)
Old Apr 3, 2012 | 05:55 PM
em1eli's Avatar
i hate qtrs, especially in the mid west
Old Jun 29, 2012 | 08:12 AM
docmanakos's Avatar
So does anyone know of a few places that sell Del Sol quarter panels, door skins or floor panels?
DocManakos@verizon.net
Old Oct 20, 2012 | 02:25 PM
Schramm13's Avatar
Where did you get new rear quaters?! i have some pretty bad ones on my del sol and i could really use some new replacements/just plain new ones.
Old Oct 21, 2012 | 06:23 AM
JarrettL's Avatar
In the post you quoted, in the text line directly above yours, he says he bought them from a member here.
Old Oct 22, 2012 | 01:55 PM
Schramm13's Avatar
Dang if someone was supplying quaters that would be great!
Old Nov 5, 2012 | 06:47 AM
Fibercation's Avatar
i could do it if you were local, ive made a few Fiberglass rear 1/4's in the past and put molded 1/4's on any cars i replace rust on. its just easier and they will never rust out again
sicilian68
Apr 23, 2018 08:07 AM
SupremeDalek209
Sep 9, 2016 04:52 PM
tschu8482
17
Jun 28, 2010 02:58 PM
EHracer06
Feb 3, 2009 02:21 PM
