h22a timing belt loseser when engine is cold then hot ??
Old Mar 21, 2012 | 10:19 AM
kldjjt's Avatar
Icon2 h22a timing belt loseser when engine is cold then hot ??
hey i have an h22a , mild head work was done to it about 3000kms ago such as valve seals , valves were replaced , skunk 2 pro 1 cams were instaled with skunk 2pro 1 cam gears , brand new timeing belt , water pump and water pump belt . when i leave my car over night to sit and go to get it in the morning i always check the oil and timing belt , well the past 2 days the timing belt has been a bit loser when i check it ( not so lose that it would fall off ) and after running the car the belt is back to normal ?? should i be worried about this or is this normal ?
backinblue92
Feb 17, 2015 05:32 PM
hector85
Sep 22, 2014 05:39 AM
withoutlimitslude
Jul 19, 2010 02:58 PM
jerryscherry
18
Mar 24, 2010 10:37 AM
