best B20 for a B20vtec build?.
Old Mar 21, 2012 | 05:32 AM
xcivictunerx's Avatar
Default best B20 for a B20vtec build?.
Ok, so I've been looking for awhile and finally just decided to write a post and see what kinds of tips I can get. After all this place is like the bible when it comes to Honda's Haha.
I'm just curious which b20 engine would be the best to use for a b20vtec? I plan on using a b16a head. It's going to be N/A. I'm just curious if there's much of a difference between any of them as far as crankshafts, cylinder walls, and anything else I may need to look for when trying to put this project together?
Old Mar 21, 2012 | 05:33 AM
BobbyRodriguez's Avatar
Default Re: best B20 for a B20vtec build?.
CRV.
Old Mar 21, 2012 | 05:38 AM
grumblemarc's Avatar
The Grumpiest
All I ever hear is B20Z.
Old Mar 21, 2012 | 05:40 AM
gold_pwr_r4ng3r's Avatar
https://honda-tech.com/forums/tech-misc-15/difference-compression-between-b20b-vs-b20z-460954/
Old Mar 21, 2012 | 06:08 AM
nealnanoHX's Avatar
A high compression B20, they came in the B20B and the B20Z. The B20Z has the P8R head which makes no difference on doing a B20V since the head is coming off.
Old Mar 21, 2012 | 07:46 AM
Ok then b20b from a si lude! Better?
Originally Posted by jdmgsr_em1
bump
why are you bumping this? im pretty sure his question was answered....
Old Mar 21, 2012 | 09:12 AM
ok stupid and unrelated question... how do i get the little cartoon version of my car in my signature? I've been looking all morning but cant figure it out...
Old Mar 21, 2012 | 09:15 AM
tensaiwung's Avatar
Prelude si got b20a. I would go with a b20b with gsr head. Ur gonna do na so the gsr head got smaller combustion chambers and with the 2.0 liter from the b20b and a gsr head is like a gsr thats a 2.0 with a better stroke. Put type r cams in it and that will make the car gain more horse.
Old Mar 21, 2012 | 09:16 AM
i think its :
user cp > edit signature > then add the image url in your sig > hit save
im not 100% if that would work tho..
Old Mar 21, 2012 | 11:53 AM
EH2Kevin's Avatar
Originally Posted by gold_pwr_r4ng3r
i think its :
I think he's having difficulty finding something like this.
This should help you.
Old Mar 21, 2012 | 02:38 PM
Civic2Fast's Avatar
The prelude b-series block won't work... not designed for the b series vtec head
Old Mar 21, 2012 | 03:11 PM
JDM_teh_WIN!!'s Avatar
99-01 B20B(JDM)
99-01 B20Z(USDM)
Old Mar 21, 2012 | 03:22 PM
Deetz's Avatar
Crazy Honda Guy
The P8R higher flow head (because it uses larger valves, same as the ones found in vtecheads).....this head was ONLY found on low compression earlier model B20B JDM models
Originally Posted by JDM_teh_WIN!!
99-01 B20B(JDM)
99-01 B20Z(USDM)
Correct, these engines are all exactly the same
Old Mar 21, 2012 | 04:33 PM
Dc4LsTeG's Avatar
EK9
Someone make me one of these of my car please.lol
Old Mar 22, 2012 | 01:35 PM
Those are exactly what I'm looking for, but how do you make them?
Old Mar 22, 2012 | 01:39 PM
And thanks guys for all the info on the engines! Incredibly helpful. Now I just have to figure out how to do an inexpensive wiring harness swap. Is there some way to step down to an obd1 harness? Or do i have to find a 99-00 civic si harness? It's going in a 95 EJ1.
Old Mar 22, 2012 | 02:04 PM
Deetz's Avatar
Crazy Honda Guy
Use your stock harness
trashkilla
25
Jun 3, 2023 05:31 AM
RedlinedEG
18
Aug 29, 2022 09:57 AM
mike-Ej8
Jun 1, 2007 02:43 AM
Jonsin
Acura TL, RL & ZDX
Aug 3, 2004 07:04 AM
