Help with Carsound Cat
Old Oct 10, 2002 | 07:21 PM
Rdriven's Avatar
Default Help with Carsound Cat
I purchased a used carsound cat, which originally came from IPS racing. I purchased it because it was a cheap way to run my stock exhaust with the 4-1 header that I ordered (DC SS). The number on the cat it 94000...Has anyone used this one before?? It has one O2 sensor hookup at the back of the cat on the exhaust side, it seems to be the correct length...Does anyone know what the length has to be to work with the dc header? The dc header has a hookup for an o2 sensor correct..so my cat only needs one (01 ITR's).
Old Oct 10, 2002 | 08:12 PM
uNF$@#!'s Avatar
Default Re: Help with Carsound Cat (Rdriven)
flange req
Old Oct 10, 2002 | 08:19 PM
Chris N's Avatar
Default Re: Help with Carsound Cat (Soup ****)
My carsound was #94066. One of the two o2 bungs was bolted shut, the back bung was open for the secondary o2 sensor. This cat is shorter than the stock cat because the jdm header is longer. What do you have? jdm dc or not? If you do not have the jdm dc, then you need the regular length cat.... I'd just contact Mike M or SMSP for help.
Old Oct 10, 2002 | 08:21 PM
Ferrell's Avatar
Default Re: Help with Carsound Cat (1107)
my dc jdm 4-1, carsounds cat, apexi n1 rattled once i installed the header and cat.
pushed the exhuast out about an inch....
Old Oct 10, 2002 | 08:32 PM
d8168055's Avatar
Default Re: Help with Carsound Cat (Ferrell)
hey man... same here, we got the exact same setup
Old Oct 10, 2002 | 08:35 PM
Ferrell's Avatar
Default Re: Help with Carsound Cat (d8168055)
.... hey man... same here, we got the exact same setup
HAD the same setup.......had it on my gsr. I kept the carsounds cat and 4-1 for the itr though
Matt1276
Sep 14, 2004 02:37 PM
pistol
Nov 26, 2002 11:26 AM
PYITR821
Sep 18, 2002 05:20 AM
01itr518
Aug 23, 2001 07:15 AM
