some newbie turbo questions
Already been searching the board a lot, but I still a couple of questions to ask:
1. is it harmful to run a 2.25 inch exhaust/ stock cat when turboed at just 6-7 psi? I know there will be a loss in power potential but will it actually do any damage? I may not have enough $$ to spring for a 3" exhaust/cat right away...
2. how does the car feel before the turbo spools up significantly. I mean before reaching full boost, will the car feel slower than stock or will there still be power gains through all the rpms?
TIA
TIA
TIA
TIA
Hope this helps.
well if your only boosting 6-7psi you don't need to spend $400+ on getting a 3inch exhust...instead i would get it tuned on a dyno. with $400 that is plenty for dyno time & runs.
-so i take that you have a common aftermarket exhust right? you'll be fine...the gains might be alittle like perhaps 3-8hp(since your not boosting high)
