EK GSR swap cel help
Old Mar 19, 2012 | 09:56 PM
Paul Elisha's Avatar
Default EK GSR swap cel help
ok so i have a 96 ek sedan. Swap is a 96 gsr with obd2 ecu. I have all the
bugs worked out except with the EVAP system. AT 1st i had a code for
FTP sensor voltage for i followed ffs squad to trick the ecu in thinking I have a FTP sensor sense my vehicle does not have one. After i did the FTP trick
now im have cel code p1457 evap canister system leak.
IM using stock ek evap canister and gsr purge solenoid.
So do i need to use a integra gsr canister, or could it be that i just have
a bad purge valve?
Any help with this evap system would be great.
I will be switching to OBD1 but i still need to pass emission so i have to
be able to pass with a OBD2 ecu.
Old Mar 26, 2012 | 12:37 AM
Default Re: EK GSR swap cel help
no one?
Old Dec 19, 2012 | 02:19 PM
Hectorzg1's Avatar
Icon2 Re: EK GSR swap cel help
Yes any1 have same issue.
Po441 and Po171 came on. I'm using Ek purge . Do I have to us gsr?. Plus what about canister?
Oscar_trucha
Jun 27, 2013 11:03 AM
efgkkid
Sep 26, 2012 04:43 PM
Pnoyej6
Nov 1, 2006 05:24 AM
