Fully Built 84mm GSR longblock
Old Mar 19, 2012 | 06:18 PM
boosted.si04's Avatar
Default Fully Built 84mm GSR longblock
It has barley over 1k miles on it. I have receipts for EVERYTHING!!!
84mm Gsr
Ge sleeves
Arias 9:1 pistons
Eagle rods
moroso oil pan
Polished victor x intake manifold
70mm omni tb
Itr head mild port job
Ctr cams
Sk2 pro series cam gears
Super tech valves
Super tech springs
Super tech ti-retainers.
Stage 5 completion clutch With flywheel
This setup will easy make over 650. It did make 517 on 18 psi on e85 I have dyno sheet. I was only on ID 1000s and a single walbro why it only made 517whp throw some 2000s it will easily make 650+ with the right turbo kit.
I am looking to sell Longblock and everything else I listed for $3,800 I have more than 6k into it building it. I will show you all my paper work. I do not mind you going through the engine I have nothing to hide. Only serious buyers though. If you take head off or anything off will be a core charge to replace the gasket.
I also have a 44mm tial wg with a 14 lb spring.
Jdm itr header not tuned one
Auto meter boost gauge and oil gauge in a 3 pillar.
Full 3" skunk2 exhaust
Hondata boost controller
Stock DC mounts with inserts
Call or txt for more info. I'm a motivated seller but I know what it's worth and low ballers will b ignored.
Thanks 503 559 0761.
Old Mar 19, 2012 | 09:40 PM
Default Re: Fully Built 84mm GSR longblock
Bump
Old Mar 21, 2012 | 09:20 PM
ekhatch44's Avatar
bump for a good guy
Old Mar 21, 2012 | 10:22 PM
Thanks enjoy the Turbo setup!
Old Mar 21, 2012 | 10:23 PM
Longblock is pending and wg is sold!
boosted.si04
Northwest (Sales)
12
Apr 22, 2012 10:19 AM
boosted.si04
Apr 5, 2012 08:46 PM
boosted.si04
Mar 23, 2012 11:05 AM
boosted.si04
Mar 13, 2012 08:19 AM
boosted.si04
Mar 6, 2012 05:57 PM
