Grinding
Old Mar 19, 2012 | 04:36 PM
Je1004's Avatar
Default Grinding
I have a h22in my accord and now I having a grinding noise on top of the head or by the timing belt does any had that problem or know what that can be need help
Old Mar 19, 2012 | 04:41 PM
dglassmyer's Avatar
Default Re: Grinding
How long has this grinding noise been going on for?
How long was the motor running properly before it started?
Have you verified oil pressure, at the sending unit and or the vtec solenoid?
Are you burning any oil?
How long since your last timing belt change?
An overtightened timing belt can make an awful noise.
Old Mar 19, 2012 | 04:47 PM
Je1004's Avatar
The grinding just started run strong haven't checked the oil pressure it's been a year timing belts been change
Old Mar 19, 2012 | 04:58 PM
dglassmyer's Avatar
I would check the oil pressure and make sure your timing cover isn't coming into contact with either your cam gears, acc belts or crank pulley.
Old Mar 19, 2012 | 05:01 PM
Je1004's Avatar
Thank you I'll check that
7rrivera7
21
Jun 3, 2014 11:46 AM
400m
Jul 1, 2007 01:59 PM
chowdaa
Apr 15, 2006 05:32 PM
R59
Honda S2000
Jul 13, 2005 04:55 AM
petrv
May 4, 2004 03:39 PM
