FS: Rust free 94 Civic Coupe Turbocharged
NO LONGER FOR SALE. Pending new drive train setup. But I am going to be selling off the turbo setup soon, if anyone is interested.
1994 Honda Civic EX Coupe 5spd
89,169 original miles ( yes that is not a typo )
Red w/Black interior
100% rust free. And has never been repaired for rust. 100% bondo and filler free.
Pictures:
http://s1218.photobucket.com/albums/...Civic%20Turbo/
Engine:
D16Z6 – Mostly stock original. Has had the timing belt replaced 3 times. Head gaskets were done and seals all replaced about 6 years ago before the turbo went on. Compression tests have held steady in the 195-200 psi range its entire life.
Garret T3/TD04 50 Trim / .48 exhaust Turbo – race bearing and wheel options
TIAL 38mm Wastegate – Currently has a 10psi spring , set to about 12.5 psi currently
HKS SSQV Blow off Valve
Turbo XS manual boost controler
RC 550cc Injectors
Walbro 255lph Fuel Pump ( in tank )
Custom Down Pipe – starts at 2.5” then goes to 3” at the oil pan ( done to clear for A/C )
Custom Dump Tube – ends just below and behind the radiator
Custom inter-cooler piping ( spent nearly 8 hours just to get it to line up perfect )
PWR Intercooler – can't remember demensions but is the 400HP model – Was flush mounted with the front bumper beam, so that it still has a real crash bumper.
PWR Radiator – 3x as thick as the factory
SPAL radiator fan – 15” wide / 3.5” thick High Output model
SlimLine A/C fan – converted to a pusher style. Keeping it in the stock location just melted fans.
Golden Eagle Vacuum distribution box
Thermal R&D 3” stainless exhaust with no resonator
Hondata s300 tuned. Last time it was at the dyno it put down 247HP / 219 FtLbs to the wheels at 12.5 PSI.
Transmission:
Fully rebuilt Y8 transmission ( chosen for stronger internals ) from a 2000 Civic EX
Quaife ATB Helical LSD
DC Sports Werks short throw shifter w/poly bushings
ACT Xtreme pressure plate with ACT 6-puck sprung clutch
Electronics/Control:
Hondata s300b – Boost and Dataloging options
Defi Boost Gauge – Green backlight
Defi Exhaust Gas Temp Gauge – Green backlight
Defi Control Unit II
Autometer Watertemp – Carbon Fiber
Autometer Volt meter – Carbon Fiber
PLX M300 wideband O2 sensor and controller
Apexi Turbo Timer
Suspension:
H&R Race Springs ( speed world challenge spec )
Koni Yellow Race valved shocks ( speed world challenge spec )
Every suspension bushing has been replaced with Poly bushings.
Powerslot front rotors with Hawk HP+ pads
Rears are stock shoes/drums
Goodridge SS brake lines. All fluids flush out and replaced with Ate Dot5
Rota Slipstream wheels in black 15x6.5 w/ Falken Azenis tires 205/50/15 ( I used to run 225/45/15 hoosier A6s for a couple years, the Azenis are the only tires I had left )
I have a full set of fresh race brakes still in the boxes. New Powerslot front rotors and Carbotech race pads, New OEM drums with custom Carbotech race shoes.
Exterior/Interior:
R1 Racing Sports front seats
Schroth 3 Race 4 point harnesses
Radio and Speakers have been removed
Accessory Auto Panel – used to house a custom gauge and controller setup
Front fenders have been rolled, stretched, and tucked to get 225s to fit with its current drop rate
Clean and basic, nothing fancy.
I am sure I am missing stuff. I also have several spares including a long block, 2 transmissions, and several other suspenion parts. Feel free to ask questions.
I'm not exactly sure of its true value, as NADA is useless when it comes to vehicles like this. I am going to start at asking $7000 and see what happens.
Pictures:
Engine:
RC 550cc Injectors
Transmission:
Apexi Turbo Timer
Suspension:
Exterior/Interior:
I had a feeling that question would be asked.
I would consider it. But only if the price offered was right. I would prefer to sell it whole and not part it out.
Well, hit me with an offer. Worst I can do is say no.
I really would hate to gut my pride and joy, but if the price is right. I will say this though, I will not have time to take it apart for several weeks.
Oh. I forgot to mention.
Still has working A/C!!
Still has working wipers and washers.
Still has working cruise control.
I rarely see cars like this that still have the above items operational.
Everything works but the radio. Which I only removed, you can easily reinstall a radio and speakers.
I get the feeling that its a higher power trying to tell me to keep it and finish it perhaps.
But then I will have to sell the CRX instead.
Got her out of the garage this week and finally drove it for a bit. Got the dust off her and took a lot more pictures of the interior.
Still puts a big smile on my face every time i bury the throttle
Sold my CRX but will still entertain offers on this. At least until I start buying parts for the spare block and building it up.
