ed6 engine change please help from Venezuela
Old Mar 19, 2012 | 06:29 AM
edgar delgado's Avatar
Default ed6 engine change please help from Venezuela
hello friends I need your help technique, I bought a civic dx ed6, and a 92 civic SI hemisphere d16a9 engine, my question is I want to spend macanica hemisphere civic engine for ed6 and let me know what steps should I follow because that the branch is obdo ed6 edl and the hemisphere is obd1 civic and I work well with the ed6 D16A9 and the other question is whether the bumper and headlights depantero ef ed6 serves perfectly?
really thanks for your help, here in Venezuela and not too few ed6 anyone ever made ​​such changes in these bodywork motor and we have no knowledge of these changes
Old Mar 19, 2012 | 06:47 AM
crx_si-r's Avatar
Default Re: ed6 engine change please help from Venezuela
What?????
¿¿¿Que???
Old Mar 19, 2012 | 06:52 AM
jlk16188's Avatar
youre better off looking in the 92-97 civic forum not he 88-91 forum.
You need to convert your car to OBD1 with a jumper harness and distributor jumper. Youre headlights and bumper should fit fine
Old Mar 19, 2012 | 07:21 AM
ok but I have a whole branch of civic obd1 hemisphere to buy wrecked, but the steps to mount it in the ed6? necesoto single engine, wiring harness and ecu to fit in the ED6? or need any additional piece?
Old Mar 19, 2012 | 07:25 AM
ok but I have a whole branch of civic obd1 hemisphere to buy wrecked, but the steps to mount it in the ed6? I just need engine wiring harness and ecu to fit in the ED6? or need any additional piece?
excuse the translation is not English and I'm using google.com translator
Old Mar 19, 2012 | 07:44 AM
crx_si-r's Avatar
hablas espanol?
you cannot use the obd1 harness, will not work.
Old Mar 19, 2012 | 07:50 AM
Originally Posted by crx_si-r
hablas espanol?
si hermano hablo español
Old Mar 19, 2012 | 08:19 AM
crx_si-r's Avatar
que es lo que quieres hacer?
Old Mar 19, 2012 | 08:25 AM
jlicrx's Avatar
FYI - D16A9 is same engine as JDM DOHC ZC
Old Mar 19, 2012 | 08:26 AM
KINGVEM^^ED6's Avatar
Donde este la carne asada¿
Old Mar 19, 2012 | 09:02 AM
sencillo hermano tengo un ed6 y quiero montarle motor d16a9 con ramal de cables y ecu....pero el ed6 es obd0 y no se que tengo que modificar para usarlo
Old Mar 19, 2012 | 09:15 AM
crx_si-r's Avatar
entones quires usar el motor en el 92 SI? o quieres convertir el motor d16a9 a la sistema nueva obd1?
Old Mar 19, 2012 | 09:33 AM
quiero convertir el ed6 en obd1 y meterle el d16a9...!!!
Old Mar 19, 2012 | 09:58 AM
crx_si-r's Avatar
entonces vas a necesitar lo siguiente:
1. computadora
2. sensor de oxigeno de 4 cables
3. distribuidor
4. un conector que te deja conectar una computadora mas nueva a tu carro.
dependiendo en cual modelo civic tienes tenderas que convertir de 2 inyectores a 4 inyectores.
Old Mar 19, 2012 | 10:09 AM
1. computadora
3. distribuidor
tengo el SI completo con todo el carro se votio y nada mas tiene el techo dañado, tiene el sensor de oxigeno,computadora y el distribuidor,lo que no se que conector que te deja conectar una computadora mas nueva a tu carro en que pag la venda o donde lo consiga?
Old Jun 28, 2012 | 05:04 PM
[IMG][IMG][/IMG][/IMG][IMG][/IMG][IMG][/IMG]
good friends as you can see the entire disarmament and cable harness that was burned, and the former owner took care not, I ask help for that here in Venezuela there are only about 10 ed6 and is far and there is little information on it, I buy a EH civic 4 door with a collision but I want to make the branch complero of OBD1 to mount in the will that omeone ed6 of you made ​​this change in cable harness?
Old Jun 28, 2012 | 05:10 PM
this is the civic SI to buy to get the mechanical cable harness and the OBD1
Old Jun 28, 2012 | 06:20 PM
villc713's Avatar
Solo ordena un harness jumper de obd0-obd1 para un carro dual point y despues metele todo el sistema del nuevo civic solo que le vas a tirrar cables para Los 4 injectores otros dos o tres cables para el distrubidor y tambien 3 cables para el sensor de oxigen si tu transmission es de 5 velocidades quadrate con Ella y compra un clutch nuevo. Te cost aria mas poniendole la transmission hydrolica. Hojala eso te ayude un poco.
Old Jun 29, 2012 | 03:54 PM
gracias por ese dato voy a tomar en cuenta el consejo la semana que viene empiezo a desarmer el SI para para pasar el ramal de cables te estoy avisando y montando fotos de lo que voy haciendo ,mil gracias
thanks for that information I will take into account the council next week I start the SI desarmer to pass the cable harness and mounting'm warning you pictures of what I'm doing, thank you
leadfoot
Jul 19, 2003 06:35 PM
red civic standard
May 24, 2003 12:29 PM
